Old 07-07-2013, 01:54 PM   #1
Speedo brain teaser
I passed four radar signs showing my speed yesterday on highway 126 from Valencia Ca. to Santa Paula.Each showed 51 when I was driving 55 according to my speedo.When I got to Ojai from San Bernardino my trip meter showed 137 miles.Is my odometer correct or did I travel less than that?Does my van really have 109,000 miles or less? I went to San Diego a few weeks ago and got 18.3333333 mpg,filling before leaving and filling upon arrival to calculate,but if my odometer is off what did I really get? I'm not sure I want to know but please chime in.
stanw909 is offline   Reply With Quote
Old 07-07-2013, 02:26 PM   #2
Re: Speedo brain teaser
As far as your speedo goes, do you have a GPS unit that displays speed?
Old 07-07-2013, 03:33 PM   #3
No gps and no phone with that capability only evert radar that I've ever passed over the course of the last year I've owned the van. Tires are proper size according to door label. 97 Dodge.
Old 07-07-2013, 05:31 PM   #4
geoffff's Avatar
What you found isn't surprising.
Vehicle speedometers are usually set at the factory to read a few MPH high -- because regulations insist that they must never read below actual speed.
This does not necessarily mean your odometer will read high.
I would have no reason to suspect the roadside radar signs are inaccurate (maybe +/- 1 MPH), especially since you found that four of them agree.
In any case, best to just check your speedometer and odometer with a GPS, or use roadside mile markers on the highway.
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 07-13-2013, 05:51 PM   #5
x(actual) = speedo
x(51mph) = 55mph
x(51m/h) = 55m/h
x(51m/h) * 1 h/m = 55m/h * 1 h/m
(the above is just cancelling the units)
x(51) = 55
x = 55/51
x = 1.07
so
1.07 * actual = speedo
and
actual = 0.927 * speedo
so for all intents and purposes take your speedo reading * 0.93 and you have your actual speed (at least as measured by CHP)
In other words, if you're going 55 mph, that's 55mph*.93 or 51mph
Odometer:
Your Odometer reads, say, 22,222.
actual miles = 0.927 * odometer miles
actual = 20,666
Miles per gallon:
Actual mpg = y * Odometer mpg
Actual miles = y * Odometer miles
actual miles = .93 * odometer miles
actual miles / g = .93 * odometer miles / g
actual mpg = .93 odo mpg
so your 18.3333333 mpg is actually 17 mpg, which if you're posting on the Internet you can claim it's 25 mpg, so it really all works out in the end.
Old 07-13-2013, 07:02 PM   #6
rionapo's Avatar
So, why is my speedo 55/58ths of actual while my odo is 9/10ths?
-Don-
Life and baseball both sometimes are not fair, but it is how you play the hops that counts.
—Scott Miller, NYT Sports
rionapo is offline   Reply With Quote
Old 07-13-2013, 08:56 PM   #7
geoffff's Avatar
Not sure where you got "58". He's saying if your speedo is reading 55/51 of actual then your odometer is also reading 55/51 of actual. So actual is 51/55 of what's showing -- or about 9/10. 51/55 and 0.927 (approximately 9/10) are all the same thing.
However, I disagree with jage's odometer assumption above, as don't I see any reason to believe your van's odometer is calibrated to match your van's speedometer. The factory can paint the numbers on your speedo dial any way they like, purposely making it read a bit high if desired -- while keeping your odometer accurate.
Best to just check the odometer using mile markers on the highway.
-- Geoff
Old 07-13-2013, 08:59 PM   #8
They're not- they're both probably 231/250ths EXACTLY. Probably, exactly that.
Old 07-13-2013, 09:14 PM   #9
rionapo's Avatar
-- Geoff
The speedometer usually runs about 3 mph below GPS at highway speeds; hence, 55/58s with tongue firmly planted in cheek. You're correct that the odometer and speedometer are related only in the sense that they're in the same vehicle. Not sure I understand why, though.
-Don-
Old 07-13-2013, 09:20 PM   #10
rionapo's Avatar
My slide rule agreed, 92.4% of the time. That solves the mystery--I just didn't calculate the actual values but let rounding errors lead me astray.
-Don-
Jnlola
jnlola
Big Grey
allenl
