Old 03-02-2010, 06:23 PM   #11
Re: Tip over point
I have a bubble and electronic, both of which were custom ordered. The slope alert is set to 28 degrees and is installed in the upper console. The bubble inclinometer is simply velcroed to the dash.
http://www.riekerinc.com/Mechanical-Inclinometers.htm
http://www.riekerinc.com/E-Inclinometer ... rt_3x3.htm
Old 03-02-2010, 06:28 PM   #12
Re: Tip over point
Jage, looks like you got the high dollar model
Old 03-02-2010, 07:00 PM   #13
Re: Tip over point
Maybe, but she supports the SMB habit, so it doesn't matter at all.
Old 03-02-2010, 07:05 PM   #14
Re: Tip over point
Yeah, clearly Jage must be independently wealthy.
Old 03-02-2010, 09:37 PM   #15
cellularSTEVE's Avatar
Re: Tip over point
Originally Posted by jage
Gets nervous at 12.5º, Screams around 16º.
Just for clarification, Jage is referring to the Green model. Apparently larger and made in Ireland.
steve
Old 03-02-2010, 10:42 PM   #16
kmessinger's Avatar
Send a message via Yahoo to kmessinger
Re: Tip over point
I always know if I am tilted too much when the beer in the refrigerator starts to slide.
If not in the Sprinter I go by the angle of gin in my martini glass.
I used to do all that "stuff" in Moab and the Grand Mesa but now, I have become more sophiscated and deboner.
Regards,
Keith
kmessinger is offline   Reply With Quote
Old 03-03-2010, 09:05 PM   #17
Railvan's Avatar
Re: Tip over point
Did you order direct from Rieker? I emailed them a question a long while back about where to buy their inclinometers and never got an answer.
Brian Rutherford
https://www.pbase.com/railvan
2006 Ford RB, 6.0 diesel, SMB 4x4, RB50
Railvan is offline   Reply With Quote
Old 03-03-2010, 10:22 PM   #18
Re: Tip over point
Yes Brian, just give em a call. They can custom make it how you want it for the most part. You just have to pay a bit more.
Old 03-04-2010, 01:52 PM   #19
CJ
Send a message via Yahoo to CJ
Re: Tip over point
Oh damn! I see it took me way too long to get back to this post.........so much could have been said...
Well, until I can get my hands on one of my own anyone want to lend me theirs? ..........um Jage? Maybe!
OUCH! Ok NOT! I had one closer than I thought.
Dave thanks for the info.
I have a camperworld bubble stick-on kind, got it for a buck-two-twenty five. I think I need one of the fancy ones that will wake me up before I tip over though. A real inclinometer.
CJ
CJ is offline   Reply With Quote
Old 03-07-2010, 02:48 PM   #20
joey2cool's Avatar
Re: Tip over point
While I prefer the sliding beer indicator, I can't pass an opportunity to pull out my engineering mechanics statics book.
My calcs were done for a 2WD base and 4-wheelers will be better off due to a wider base.
The problem statement is "Find the maximum hieght where P is the force that may be exerted without tipping the van over."
h = b\2u = 37.2"
Where,
b = base = 67"
u = friction coefficient for rubber on dry smooth pavement = 0.9 static (or 0.8 kinetic)
You want the van's center of gravity (cg) to be below h. P is going to be determined by the van's gross wieght (assume GVWR if the van is not overloaded), plus the force of acceleration if you are moving.
The 2010 Ford E250 RB center of gravity is 32" (floor hieght) and 31" for the E350 SD. Each conversion is going to be unique and you will have to calculate your new cg based on the weight and location of each added item in relation to the original cg for summation of your new cg.
Interestingly, Ford sets the maximum allowable cg for converters at 45.8" for an E250 with 8,000 GVWR. However, they reduce this to 39.2" when their Roll Stability Control (RSC) system is installed. Due to their liability, I figure these are conservative figures. Results from the academic formula appear to be even more conservative (not sure why, but it most likely has to do with the model used; i.e., a solid rectangle versus an object with wheels).
Being at an angle will raise the van's center of gravity. My trigonometry is rusty. Can anybody lend a hand with the math and tell us how many additional inches you lift the van when it is tilted at 30 degrees?
Silver Bullet
joey2cool is offline   Reply With Quote
White rhino
DIY4x4guy
Rex
Tomboy
