06-09-2014, 10:33 AM
Tire carriers
Hello from Hiouchi Ca. Does anyone have a "pre-aluminess" tire carrier? The old square tube type. Are they stronger then the Aluminess design?? I am looking for the strongest option in production? I never has smart enough to buy something that I can make better and cheaper. Thanks to LA city schools! We had the best metal shops in the country and teachers! 40 yrs ago....... Will the old style tire carrier hold up to wash board roads? If you go to Baja or any southwestern desert you know what i'am talking about! Even with low tire pressure your interior tries to release itself from the vehicle!! Thank god for 3M 5200 marine adhesive.........Se Ya Later up the trail!!!
06-09-2014, 02:30 PM
Re: Tire carriers
Renuel?
06-09-2014, 02:36 PM
Re: Tire carriers
I have a Reunel square-tube carrier.
The hinge and latch are not as nice as Aluminess. My latch sheared off and now I use a cam-strap to keep it closed. Before it broke the latch wallowed out the arm and the clattered a bunch. I plan on upgrading to some nice cam-lever latches, if I ever find some time this summer.
06-10-2014, 08:01 AM
Re: Tire carriers
06-10-2014, 09:01 AM
Re: Tire carriers
Originally Posted by 86Scotty
Do you mean a swing arm style or the bolt-to-the-door style? If you mean the latter I have 2, both homemade using the SMB mounting holes and the original rusty one as a template. I haven't road, err, off-road tested them yet but I will be soon. I'll report back if they fall off.
Wow, I had forgoten about the SMBforum stickers like you have on your rear window. That's a flashback in time.
06-11-2014, 10:29 PM
Re: Tire carriers
06-16-2014, 10:28 PM
Re: Tire carriers
Lol. I here ya. Mines still there so far!
06-16-2014, 10:30 PM
Re: Tire carriers
Yeah, they were a door prize from Jage when I stayed in his driveway once. I like em. I have one more but don't want to waste it so I'm waiting on the right spot.
06-17-2014, 04:42 PM
Re: Tire carriers
Recently had a friend lose his (on a jeep, not a van) with a setup even beefier than aluminess.
Some fab shops will sell you super bearings to mount a swing on. But figure tire and wheel at 75lbs at least, and then weight of frame.
I keep looking at designs deciding what to build, and finally got convinced by others that if I really wanted the strongest I should go for a racer-type carrier that drops backwards and down, not a swingarm. Guys make the pivot out of tubing, and it can sit pretty close into the back. And sometimes be integrated into the bumper.
The problem, as I see it, is first, how to secure it from flopping down, and second, the fact that it's pretty heavy to drop over and then put back up. Some RV vans have these jack type arrangement that can lift one, but I don't think they make them now.
If I could forego opening the rear doors, or was willing to put the tire back a bit further so I could at least crack the rear a bit, I'd just go with a trailer hitch mount and probably some DIY additional support to the bumper to prevent clanging around.
Right now I have room inside the van for a spare, so I'm OK. But love to see what you come up with.
Rob
06-17-2014, 09:12 PM
Re: Tire carriers
Rear camera and check it often. Or, put a pin switch and an alarm on it so if the tire falls it alerts you. I know, it's a stretch.
