Old 07-14-2008, 10:01 PM   #1
zugg's Avatar
Where are the condensation drainage holes in a Ford van?
Greetings,
Does anyone know where there are condensation drainage holes for a Ford van?
I have heard that they are at the base of the left and right sidewalls.
I will be spraying Lizzard Skin and I want to plug these holes for the application. Once done, the holes are unplugged.
Any advice is appreciated.
Zugg
Always do your best!
zugg is offline   Reply With Quote
Old 07-14-2008, 11:22 PM   #2
The drain holes are located inboard, at the base of the rocker panels. Look where the inner and outer body panels are welded together. There is a seam about 1" tall where you'll see that the inner panel has channels formed in it that allow water to drain.
I hope this helps.
John K.
John Kalmbach is offline   Reply With Quote
Old 07-15-2008, 08:52 AM   #3
zugg's Avatar
Hi John,
Thanks for the tip!
I will be looking for the drainag holes today.
Zugg
Vanzilla
Glenn P.
Rufus
LARufus
