Old 03-15-2014, 11:29 PM   #1
geoffff's Avatar
My Fire Extinguisher Works!
OK, one more Baja trip story.... I got a chance to try out the fire extinguisher supplied with my 2004 Sportsmobile. Actually, I'd never used any fire extinguisher before this. In any case, it works!
I was happily bouncing along on a dirt track, when all of a sudden I felt a loss of power. Glancing, down I saw all my gauges go haywire -- with the speedometer doing its full-sweep test mode. And, I smelled smoke. Eek!
I immediately pulled over, stopped the engine, and gave everything a thorough looking over. I couldn't find anything amiss, so I gingerly started the engine, and started driving onwards. One minute later, it happened again. Engine completely died. More smoke. Now pouring out from under the hood!
Key off. Brake hard. I yanked hard on the fire extinguisher from behind the passenger seat, pulling it out. (Luckily that's all there is to removing it.) I popped the hood (perhaps a mistake) run outside, and see flames coming out from the battery area on the passenger side of the engine!
I realized I'd never used one of these things before, but here goes... A few squirts with the fire extinguisher, and the fire is ... out! Phew!
OK, what the #### happened?!?
I quickly removed the battery. Then I blew out much the accumulated fire extinguisher dust and took a look around the engine compartment.
I notice a sooty broken braid wire next to the battery:
And another next to the ExtremeAire circuit breaker. I vaguely remember that braided copper wires like these are some kind of grounding strap. And perhaps they are meant to melt when overloaded by a short?
The braided strap next to the ExtremeAire looks suspicious. Had it been touching that bolt next to it? Sure enough, that bolt is live +12v.
I check the battery cables (now disconnected from the battery) with my multimeter. Yes, something was still causing a short! What was shorting? Something major!
In any case, I knew I had to repair the grounding straps. I found three melted grounding straps, and hacked up some fixes:
At this point, it was getting dark, so I camped right there on the road. After lots of sleep, in the morning I got back to tracking down that short. Luckily all the house battery appliances still work with the engine battery disconnected.
I noticed that three red cables had been bolted to the battery. I assumed one was the stock Ford cable, and two more were added by Sportsmobile. Checking with my meter, I found that only one of these three cables was shorting to ground. A thick one. Now I was getting somewhere.
I followed this red cable back, as it left the rear of the engine compartment, and followed the passenger side of the frame back to the house battery. Hmmm, the house battery didn't look right:
The red shorting cable followed the frame of the van up to the house battery, then passing alongside it and out the other side. I pulled this cable out and found the short. The house battery had rotated out of its pan, and was pinching the red power cable against the van, causing this:
Sure enough, pulling the cable away from the van body fixed the short. I wrapped this cable with lots of tape and conduit.
Righting the heavy house battery wasn't trivial. I finally managed to get it to budge by using the van's bottle jack, and wriggled it back into its tray. I then used thick garden wire to strap the house battery down, positively attaching it to its tray.
If you like to drive bouncy roads, you might want to check your house battery too -- it might be worth your time to tie it down like I did.
I don't know what I would do if that extinguisher hadn't worked! Next time I'm buying two!!
[edit: Here is the full story of my Baja adventure: Baja 2014.]
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 03-16-2014, 12:15 AM   #2
rockbender's Avatar
Re: My Fire Extinguisher Works!
Awesome job on the diagnosis / fix and thanks for slowing down enough to take photos! I would have been so stressed out that taking a camera out would have been the last thing I would have thought about.
Josh
Old 03-16-2014, 08:41 AM   #3
yvrr's Avatar
So, Geoff...
Other than getting stuck, blowing a tire, and starting a fire...how was the trip?
Jack
'01 Ford EB50p Quigley 4WD
Old 03-16-2014, 08:58 AM   #4
Gooseberry's Avatar
you are lucky really. It looks like the house battery cable shorted to the body and the ground straps became the fusible link ( not really designed for that) back to the frame that the house battery is grounded to. Had that grounded to the frame it would have been a whole different outcome.
Again nice job and fix.
Old 03-16-2014, 09:20 AM   #5
Great work. If you used a common household fire extinguisher, you should get in there right away and clean off the residue. It's my understanding that the residue is corrosive.
Halon ($$$) is preferable, but there is at least one halon alternative (halotron). Still not cheap though.
Old 03-16-2014, 10:02 AM   #6
geoffff's Avatar
Well, you'll notice there aren't any photos of the smoke/fire part of that misadventure!
It's a new thing for me -- I'm trying get myself to slow down and document everything. I have so many lost stories in the past for which I was too freaked out to photograph. Why do I do all this, if not to remember & share?
-- Geoff
Old 03-16-2014, 10:14 AM   #7
larrie's Avatar
Good job sleuthing the problem. Glad you wrote this up. I travel by myself as well and your write ups help me plan for the unexpected.
Larrie
Old 03-16-2014, 10:39 AM   #8
Jeffrey's Avatar
Kudos to you Geoff for the top notch detective work and creative repair, especially solo and remote. I'll test my extinguisher this week and maybe keep a spare around.
Old 03-16-2014, 12:43 PM   #9
Viejo's Avatar
Excellent field repair and excellent write up. Thank you!
2002 E350 7.3 PSD
Quigley 4x4, EB50 floorplan
