Old 01-14-2014, 08:12 PM   #1
MrHenrietta's Avatar
How to Install Fender Flares?
I couldn't find a thread or youtube on a Bushwacker Fender Flare Install for and E-350. Is there a guide out there somewhere?
2003 7.3 UJOINT 4x4 SMB
Old 01-15-2014, 11:36 AM   #2
Re: How to Install Fender Flares?
Double sided tape and some screws. That's it.
Old 01-15-2014, 12:36 PM   #3
Thanks. They arrive on Friday. Just wasn't sure If there was any drilling involved. If that was the case I was thinking about having my local shop install.
Old 01-15-2014, 12:39 PM   #4
Even I can install them.
Actually comes with a rubber tape that you push along the edges between the fender flare and body. Then uses same screw holding in your existing plastic wheel well lining.
That's how it was for my f250. Pretty sure it's the same for the e-van
Old 01-16-2014, 09:39 AM   #5
yvrr's Avatar
SMB West installed the ones on our 2001 Ford but I still have the instructions. Let me know if you'd like a copy...
Jack
'01 Ford EB50p Quigley 4WD
Old 01-17-2014, 09:03 PM   #6
pinz712's Avatar
We just did ours tonight. Front uses ford screws. Rears use self taping. No holes through the side of the van all the screws are inside the wheel well so if you mess up only you will know.
pinz712 is offline   Reply With Quote
Old 01-18-2014, 06:04 PM   #7
Just installed them. Front was just screw in. Rear I had to drill holes but it was pretty easy. My van is 99 E-350 fwiw.
