Old 12-27-2010, 06:35 PM   #1
Redo the plumbing and moving flat plate water heater inside
Hi all,
I guess I should introduce myself first, my name is John and my wife and I own a 06 EB 6.0 Diesel with a slightly modified RB50 build out (we had it pushed back about 7" so we would have a little more room in the living space and there is still room enough in the back for two bikes). We picked up our van in January 2007, and from the start I had planed to install what I could myself to save some money and do things the way I thought they should be done. A few of the first things I did was tint the windows, install a bigger transmission cooler, install the Espar coolant heater and furnace, make custom space efficient drawers, install a back up camera, solar panels and controller and so on. In the four years we've had it, it's never stopped (just ask my wife) and now that I have discovered this forum, you guys have given me all kinds of new project ideas and solutions to problems I didn't even know I had. Don't even ask why it took me so long to hear about this forum, all I can say is I'm not very computer savvy. The only help I had was Eric Badge's Blog, my wife found it while we were in the process of having our van built. By the way, if you come across this post Eric, thanks for that. So now I have some catching up to do. Unfortunately for most of my mods an self installations, I was not taking pics of my process and/or progress, so I will only have pics of the finished product of most things.
I will post these separately to make it easier for the search function.
One of the last big projects that I took on was to redo all the plumbing in the van. We do our share of cold weather trips and we have had a lot of problems with our lines freezing. I think the biggest contributor to this (as anyone that has this type of water heater will know) was that the flat plate water heater was mounted outside. I have wanted to move it inside for a long time, I saw that Eric Badger had done this and I knew that it would help. When the original flat plates were recalled and we were up at SMB west having ours replaced, I ask what they thought of putting it inside and they said it was a bad idea. The risk of the coolant contaminating something was to great. I didn't buy it for a second but that was all my wife needed to hear. So all I could do was try to insulate the heat exchange where it was. I built an enclosure and with access to the drain valves insulated it as best as I could. This helped a little but the lines would still freeze on occasion. Until last March when we were on a month long ski trip and a few 1 degree nights sleeping in the June Mt. parking lot, the flat plate ruptured. Even though I had shut off the supply valve and drained the core. It turns out that the valves in the shower also were damaged and the heater was refilled with back flow from the shower. Fortunately the coolant ports staid intact so there was no big mess. It was over $400 to replace that heat exchange so that's when I started drawing up the plans to move it inside.
The first thing I had to do was convince my wife that it could be safe (after spending the money for a new unit, this was a bit easier to do). I just had to put a "worst case scenario valve" in the coolant lines.
This cluster of three ball valves allows me to completely bypass the flat plate or minimize the amount of hot coolant that passes through it, to control the temperature of the water from the faucet, without cutting flow to the Espar coolant heater. And this has been mounted where the flat plate use to be.
I put the heat exchange in the cabinet under the sink. I am obsessed with maintaining as much storage space as possible so I wanted to take up the least space that I could. I was able to put it under the self in that cabinet and only lose a 7"x 8" spot on the floor.
It's hard to see in the photos but I put a shutoff valve on the supply and exit of the potable water so there can be no back flow. I also put a drain valve on both ends so there would be an air supply for a quick and complete evacuation of the water. Those are the two lines you can see going into the floor. And all of these valves are 1/4 turn ball valves with Pex fittings. I built a two sided enclosure and put a double layer of bubble insulation on all the inner surfaces to minimize the heat that might build up in the rest of the cabinet.
This has all been working quite well but we have only been in temps in the low 20s, so far.
Worst case valve bypass for flat plate 3.jpg   Relocated flat plate 3.jpg   Relocated flat plate 5.jpg
jwintersteller is offline   Reply With Quote
Old 12-27-2010, 06:56 PM   #2
Re: Moving flat plate water heater inside
One of the big reasons I was redoing the plumbing, was that I wanted to move all the water lines off the floor as far as possible. When we camp in cold weather, I can really feel the cold creeping in through the floor. Even with the heater on, standing on the floor in bare feet, I could feel a 2 to 3 inch layer of extreme cold. We have had our water pump freeze and this would cause the fuse to blow. And there have been many mornings with no running water. With the lines on the floor and all the heat rising, it would be the last things to thaw. So I flipped the water pump and move all the water lines to a minimum of 12" from the floor. I'm hoping that even if the lines freeze, they may thaw much sooner.
Now there is only the filter and 2" of pipe close to the floor.
Old 12-27-2010, 07:14 PM   #3
Moved the shower onto the back door.
The final stage of the plumbing overhaul was putting the new shower in the drivers side rear door. The new shower with the removable hose (that I bought from SMB west about 2 years ago) the line was to short to use from were the original shower was. The other problem I had with this location was the distance it was from the water heater, I would have to push a fair amount of water before it would warm up. By putting it in the door, I cut the distance almost in half. And now the hose is more then long enough.
I ran the water lines along the top of the deep storage under the closet, and when that cabinet came to an end, I made a 90 degree turn towards the outer van wall. I installed shutoff valves at this point, just in case there is a problem down the line.
Making another 90 degree turn into the wall of the van to get to the rear corner right at the taillight. This is were I stopped the Pex line and went to the braided hose to get from the van body to the door.
I know this will be a vulnerable point for freezing but I don't plan on using the shower in those conditions and I know that the Pex and braided line will hold together. The only thing I am worried about are the 90 degree Pex to 1/2" plastic female pipe thread, there are 4 of these fittings in the door and I know they can brake if they freeze. I have seen this fitting with a brass 1/2" thread but I just can't seam to get my hands on them. Both of the braided lines fit through the existing cable housing, with just a little bit of tweaking. It was a very tight fit to get the shower in the door. I wish I had taken some pictures of this before I put it all in, sorry. This has all been in use for about 4 months and so far so good, the up coming cold months will be the big test.
shower relocated to door 3.jpg   Moving shower to rear door 3.jpg   Moving shower to rear door 5.jpg
Old 12-28-2010, 10:40 PM   #4
Re: Redo the plumbing and moving flat plate water heater inside
Fantastic write up. Nice job.
Otter
Turtle
rafeman
