Old 06-13-2015, 09:53 AM   #1
Air Conditioning Issue
A/C recently quit working...bud hadn't yet had a chance to get it in for diagnosis but then, yesterday, I took the van out for a quick trip. A/C was off but I had the blower on high with the vent setting only. As soon as I returned and reached my driveway the "check gauges" light illuminated. The engine temperature was at the top end.....HOT. I shut her down and heard hissing and found a pretty good sized leak already forming from the side (driver's side) about half way down. Underneath the A/C lines running to the back of the van were venting steam and condensing fluid to create the leak. It took quite a while for the hissing/leak to stop. To me the fluid definitely smelled like A/C fluid.
Any ideas what is going on?
Jepa is offline   Reply With Quote
Old 06-13-2015, 10:36 AM   #2
4x4sporty's Avatar
Re: Air Conditioning Issue
Sounds like the rear heater hose instead of the ac. Probably reason for overheating.
Old 06-13-2015, 10:59 AM   #3
I agree
Old 06-13-2015, 11:13 AM   #4
Yep. Coolant lines run to and from rear unit if you have rear ac. Sounds like you might have 2 problems though.
Old 06-14-2015, 12:19 PM   #5
Hmmm....good points. The Espar is back there too. I wonder if it might have caused the issue. I will look into it.
Thanks guys.
