Old 09-28-2015, 11:45 AM   #1
SixCardCharlie's Avatar
Alternator Front Wire
Can anyone tell me where this wire gets connected to? It's just loose.
2004 6.0 PSD
SixCardCharlie is offline   Reply With Quote
Old 09-28-2015, 12:54 PM   #2
Bbasso's Avatar
Re: Alternator Front Wire
I think the more important question is, where is it coming from and does it have power?
Rob.
Current:
And had three other E350s...
Old 09-28-2015, 02:20 PM   #3
arctictraveller's Avatar
It looks a lot like a ground wire. Look around for a missing bolt with evidence of the terminal having scraped the surrounding metal. It has to be somewhere within the reach of the wire, just move it around without pulling too hard to see where it might fit. After of course having tested it for voltage to ground..
Arctic Traveller
KC6TNI
2001 GTRV
Advanced 4wd
Old 09-28-2015, 03:34 PM   #4
BajaSportsmobile's Avatar
Looks like a ground wire to the body.
Old 09-28-2015, 05:44 PM   #5
Yep, which is to say something on your van that doesn't work is about to. Has it been like that long?
Old 09-28-2015, 08:00 PM   #6
I've had it for about 2 months an this is the first time I've noticed it. It's also been to a mechanic once so he may have done it. If not who knows lol.
2004 6.0 PSD
Old 09-28-2015, 09:11 PM   #7
Looks like one that has to be disconnected when you replace the fuel filter.
Old 09-28-2015, 09:20 PM   #8
Well, maybe. That looks like one of the main harness grounds, which is more like an electrical noise suppressor, which really helps to make things like the FICM last longer and prevents weird faults like can-bus errors.
Old 09-28-2015, 10:10 PM   #9
Makes sense. I had a mechanic replace them while he was in there working on somthing else.
2004 6.0 PSD
Old 09-28-2015, 10:35 PM   #10
I agree that it looks like a body ground. It probably goes under the bolt in the top left of your picture. The washer on the bolt looks to about the same size as the worn area on the connector.
