Old 02-25-2015, 08:11 AM   #1
haywoodphotomaccom's Avatar
Leaf Springs setup advice/opinion.....
I have had the Deaver spring pack on the rear of the van for a couple of years now. As mentioned in another thread I was not happy with the ride right off the bat.
To get it to ride better we pulled several leafs out which dropped the van 3-4 inches in the back. We put blocks in to level the van. The van still sits a little low in the back and I really need an even taller block to level it out. Plus I would really like to pull one more leaf out to smooth out the ride even more. It rode great with the one extra out but we had to put it back in to get close to level.
The question/thoughts I have on this: I don't like having blocks to level the van. I wish the springs were holding the load and keeping the van level with a great ride. Do I put the taller blocks in and just forget about it or have some form of adjustment made to the spring pack? Or do I just sell what I have now and have a new pack built?
I just keep thinking that if had the correct spring pack installed I would get back 4 inches of spring travel with those springs instead of having 4+ inches of blocks to make up the difference.
I think if I pull another leaf I will need a 4-5 inch block to bring the van level.
Old image for reference only as I know we all like photos in posts.....
Brent
2006 Quigley V-10 (Sold)
Old 02-25-2015, 10:04 AM   #2
Re: Leaf Springs setup advice/opinion.....
At this point I think new spring packs are your best bet. Taller blocks will cause more axle wrap, which will cause driveline vibration during hard acceleration, and can cause the rear tires to lose traction sooner while braking. Since you know the spring combination that provides the best ride, it will be easy to have new spring packs made to match that spring-rate, but with more arch to provide the desired ride-height.
Old 02-25-2015, 10:23 AM   #3
arctictraveller's Avatar
Did you talk to National for ideas?.........
Arctic Traveller
KC6TNI
2001 GTRV
Advanced 4wd
Old 02-25-2015, 10:39 AM   #4
Thinking new springs too.....problem is both National and Deaver did not build them to my requirements to begin with. I gave Deaver & National very specific personal use needs and both build them incorrectly. Maybe third times a charm......
Partial reply to PM message sent to me.....
Brent
Old 02-25-2015, 10:53 AM   #5
BajaSportsmobile's Avatar
Pull them out and bring them to me next week, along with the leafs we pulled out and I will get them "fixed" for you!
While we are at it I'll order you a new lower steering column.
I'm flying back to SD on Sunday - we will need them for a few days.
(PITA) lol
Old 02-25-2015, 10:55 AM   #6
Sounds good!!
Brent
Old 02-25-2015, 02:35 PM   #7
Check out Roadmaster Active Suspension, no axel hop.
www.activesuspension.com
