Old 04-17-2014, 04:36 PM   #1
TheYeti's Avatar
Cargo Van Ford E-350 2007 Diesel - $750
No affiliation, figured someone here might be interested so why not post it up.
http://seattle.craigslist.org/see/cto/4427750236.html
TheYeti is offline   Reply With Quote
Old 04-17-2014, 04:44 PM   #2
Re: Cargo Van Ford E-350 2007 Diesel - $750
If the description is accurate, the parts alone are easily worth the price.
Old 04-18-2014, 07:45 PM   #3
I wouldn't pay that much for it. 250k is pretty much the end of that motor. I suspect by "oil pump" they probably mean HPOP. Tearing that far into a 6.0 with that many miles, you're probably better off just buying a Ford reman. By that age, you'd probably be earning yourself a new engine wiring harness because any invasive work will probably introduce new electrical headaches. And of course bad HPOP often means new injectors.
The 5R110 go for about $350 at the wrecking yards. It only has a semi-float rear end which also go for about the same price. So I guess once you scrap the rest of the van, you could make a little money but it has headache written all over it.
Old 04-18-2014, 07:52 PM   #4
If the fuel injectors are actually new, that's worth the price of admission alone. Even a single remanufactured injector is close to $200.
