Old 04-23-2015, 12:01 AM   #1
ArikB's Avatar
Leaking fuel line
Hi all!
I own a 2005 E-350 Super Duty 6.0
Recently there is a small leak from one of the fuel lines (marked in the attached pic)
I need a little help finding the OEM part nuber for this fuel line
Thank you.
2005 Quigley E-350SD 6.0L
ArikB is offline   Reply With Quote
Old 04-24-2015, 03:08 PM   #2
ArikB's Avatar
Re: Leaking fuel line
Found it!!!
Old 04-24-2015, 03:40 PM   #3
Now just make sure you get the right prefix and suffix... the middle part of Ford's part numbering system can be really misleading (there can be a number of parts that share the same middle numbers). If you're ordering straight off of http://www.fordparts.com, you probably won't have much trouble when you look up parts by VIN# but if you want to save money ordering somewhere else, you'll need to know the first 4 digits and last 1-3 digits.
See here for deciphering Ford part numbers...
http://www.schooledinthetrade.com/index ... &Itemid=54
mgmetalworks is offline   Reply With Quote
Old 04-25-2015, 12:14 AM   #4
ArikB's Avatar
Thank you!
