Old 06-13-2015, 08:22 PM   #1
F250 rims with full float rear.... Issues?
I found a set of factory alloy wheels online that are within my budget. Before I pull the trigger on them or drive an hour to inspect them I wanted to check for compatibility issues that may be obvious to those with more knowledge than me.
I have a 96 e350 with a full float rear. The rims are stock alloy from a 97 f250 so I do know the lug spacing works. My main concern is the axle clearing the opening in the middle of the wheel.
If someone knows this will or will not work, please inform.
bcaine is offline   Reply With Quote
Old 06-14-2015, 08:58 AM   #2
Re: F250 rims with full float rear.... Issues?
Axle hub is 4.88" on all E-series and the old-body F-series, so you'll be good!
