http://www.zampsolar.com/index.php?m...id=1423&page=1
the above link is for the Zamp solar system we installed. This 200 watt, 30 Amp kit is designed for a 3 Port Solar Roof Cap. These 2 - 100 watt panels put out 11.2 amps of charging power. Even in less than full sun, I am getting 6-8 ah continuous. It is the best improvement we have done so far for the Van, by far. Now, this winter I might be singing a different tune when we can finally utilize the Diesel Heater.
•2 - 100 Watt Zamp Solar Solar Panel
?Class A Moncrystalline - Highest Efficiency, Highest Quality
?39 1/2 x 26 1/2 x 1 3/8 per panel
?17.9 lbs Per Panel
?11.2 amps per hour under optimal light
•30 Amp Digital Deluxe Solar Controller
?5 Stage - Soft, Bulk, Absorption, Equalization and Float Charges
?PWM
?LED Read Out Light
?LCD Read Out
•Zamp Solar "Z" Bracket Mounting Feet for panel(s)
•10' UV Rated Solar Panel Wire - Pre-wired with Zamp Solar Plug (Fits to Roof Cap)
