Old 06-22-2015, 10:22 PM   #1
LenS's Avatar
Great Ideas from the People Down Under.
I become more impressed with the Australians every time I see one of their rigs. This one is a beautifully outfitted teardrop trailer. Lot of great ideas for a very limited space. Would cost about $20 US but you still have to get it home. Look at the fit and finish on this rig.
Len & Joanne
The Green TARDIS
Old 06-23-2015, 09:14 AM   #2
Re: Great Ideas from the People Down Under.
That slide is brilliant. If only one could adapt that to the rear of our vans....
Old 06-23-2015, 09:29 AM   #3
E350's Avatar
Wow! Form, brilliance, and well-vaccinated too!
Old 07-04-2015, 04:31 AM   #4
Here's something that we might be able to DIY ?
Old 07-05-2015, 09:50 AM   #5
That teardrop is brilliant!
Old 07-06-2015, 03:36 PM   #6
Loved the DoubleBack VW slide out. Store anything you want in the back 6'. Set up camp and slide it out and you have full space up front. SMB could do this easily.
Rosy
Isever
"Campy"
campy
