While the Truckfridge is well insulated, posts by BadgerTrek and others found their fridges ran less after adding more insulation, so I followed their lead. I made an insulated tortion box shelf for the fridge to sit on with a frame, 2 hard board skins and some foam insulation in the hollow space. Here, one side is skinned and the second piece of foam is about to be placed:
With the last foam in place, the second skin can now be glued and stapled into place:
The length of the shelf is a couple inches short of the back of the cabinet to provide the needed vent space.
The inside of the cabinet is 15-1/2" and the fridge is 15" wide, so there was just enough room for some foam-core board on each side. Wood strips were added at the front edge to hold the fridge securely. Since the fridge sits on 4 rubber feet, I cut a couple layer of foam-core to fit between the fridge and the shelf, notched for the feet:
I also attached 1-1/2" of foam to the back of the fridge below the mechanical equipment with carpet tape.
The fridge was wired and set into place and screwed to the cabinet through the face frame.
The wiring is long enough for the fridge to be removed and set on the floor before disconnecting.
This shows the vent/mechanical space at the back of the fridge. The inside upper back panel is now in place for the vent space to the top of the cabinet:
The wiring runs behind the back panel which stops short of the top of the cabinet to provide the vent path. The vent holes at the top of the face frame are also partially visible:
Two pieces of 1-1/2" foam were cut so they tightly press into place on top of the fridge. A gap was left in front for the front trim piece:
This shows the finished cabinet above the fridge. The lower shelf has the front trim piece attached to it and can be lifted out to facilitate fridge access when needed:
The finished installation:
The gap at the top of the low cabinet door below the fridge provides the ventilation air. The cabinet and fridge doors are all hinged on the right for convenient access from the gaucho. The cabinet doors were cut from the old tall door and a 1/8" oak strip was used to finish the cut edges. Some more hooks were also added.
As a part of this install, all of the door and drawer slam latches and pulls were replaced with Southco M-1 latches
viewtopic.php?p=49650#p49650 and the old screw holes were filled with matching putty. Finished view from the rear of the van:
The new counter is also visible
viewtopic.php?p=68330#p68330
This ended up being a long post, but I did not find a new-fridge installation post here, only posts on replacing existing ones. I hope someone finds it useful. Thanks to Jage for the wire-fishing hints and Badgertrek & others for fridge insulation notes.
