Old 03-26-2014, 05:02 PM   #1
Roof Rack-Gutter Mounts or Track Mount?
I need help deciding which route to go on a roof rack for my Sportsmobile. Option 1 is a track mount system like they do on truck shells. Option two is gutter mount that bolts to the side of the top. I feel like I want the ability to move the load bars back and forth which can only be done with the track mount. What do you have and why do you like or dislike it?
Track Mount: http://ep.yimg.com/ca/I/orsracksdirect_2267_46573670
Gutter Mount: http://ep.yimg.com/ca/I/orsracksdirect_2269_107517622
CapitalE is offline   Reply With Quote
Old 03-26-2014, 06:32 PM   #2
Re: Roof Rack-Gutter Mounts or Track Mount?
I would go for the tracks simply because it's a cleaner, more modern design. I've had both and both work about the same.
Old 03-26-2014, 09:58 PM   #3
Track mounts means you gotta drill holes in your roof. Why do you think you can't you move the rain gutter mounts back and forth?
Old 03-27-2014, 06:57 AM   #4
Rain gutter mounts on a PH top, which is what I assume the OP has, require drilling into the PH to mount the brackets to support the raingutter towers. Once those brackets are fixed into the roof, the towers really can't be relocated.
Old 03-27-2014, 09:28 AM   #5
Sorry, I should have clarified. The gutter mounts would be fixed to the side of the penthouse top. Thanks for the replies so far.
Old 03-27-2014, 10:22 AM   #6
Oh that makes sense. I was assuming you had a factory roof
Old 03-27-2014, 12:20 PM   #7
yvrr's Avatar
Don't worry about drilling into your penthouse top. SMB installs the tracks outside of the canvas sides so it doesn't make any difference if the holes leak water or not...the water simply drains outside the canvas sides. Just use big fender washers on the undersides to spread the load...
Jack
'01 Ford EB50p Quigley 4WD
