Will Agile no longer do the install? You are so close to SD if Agile will do it there is no other shop out there that has worked on more vans...
Saw in your profile that you have an EB econoline. I am on my second Quigley that I did an Agile RIP kit too and this time around I went with a custom rear spring pack built for the loaded weight of the rear axle. Makes all the difference in the world. If it is in the budget I would highly recommend. Agile also used to offer an "add a leaf" that helps too and is cheaper.
Hey clicker. Yup got custom rear leafs. Agile wanted 2 days with the van which means either 2 trips to SD or staying overnight. I need ball joints swapped too and I don’t think they’ll do that.
Nice on the leafs. You will be stoked. Good call on the install...I was really bummed out that when Agile did mine they would not do ball joints. They did on my first van before they were a couture Sprinter shop. John was stoked to work on Econolines and took pride in it. My last visit to them will be my last.
