Old 03-29-2024, 02:17 PM   #1
Looking for shop to do differential work
I've got a 2002 E350 7.3l Diesel with quigley 4x4, about 170K miles. I am near Moab, Ut. My rear diff is creating a little binding during sharp turns, especially after the vehicle warms up. I've had it checked by a good mechanic who suspects wear in the rear diff. Unfortunately he is not equipped to do the work. Can anyone suggest a place to get this worked on, the closer to Moab the better.
Thanks In advance
Glenn Kincaid
trouts_gtk is offline   Reply With Quote
Old 03-29-2024, 02:35 PM   #2
Twoxentrix's Avatar
This Map contains Shops recommended by Members - just zoom in till you uncover the closest to you. *Good change there are other options in your general area which are not on listed.
https://www.google.com/maps/d/viewer...4375609375&z=7
Old 03-29-2024, 04:54 PM   #3
1der's Avatar
First - What is the axle code on the driver door jamb sticker assuming the rear axle has not been changed?
Do you have a rear locker?
If it is a limited slip (Axle Code beginning with a C ) then first get a bottle of Friction Modifier and put that in the rear diff case. That may be all that is going on.
https://www.motorcraft.com/us/en_us/...modifiers.html
If still binding then different issue.
Old 03-29-2024, 06:38 PM   #4
Mine did that. Turned out to be classic clutch pack wear - very common. If you are on the road, it's normally just an annoyance and not a critical show stopper. I waited until I got home to fix it. BTW was able to do it myself. Total cost about $150 for everything.
Old 03-30-2024, 07:38 PM   #5
keytothestone's Avatar
Village autocare in Durango did mine 4yrs ago. Good folks. 3hrs away
keytothestone is offline   Reply With Quote
Old 03-30-2024, 09:23 PM   #6
joefromsf's Avatar
Another option in Durango is Vandegrft Deisel. They corrected a bad front end alignment service by my local shop when I was on a road trip. I was very pleased with their work.
https://www.vandegriftdiesel.com/
--Joe
2012 E350 RB XLT Wagon, Agile 4x4, SMB penthouse
joefromsf is offline   Reply With Quote
Old 03-31-2024, 06:44 AM   #7
You shouldn't need to leave Moab these days to find a good shop to do this.
