Old 10-04-2015, 10:24 AM   #81
dokaman's Avatar
Re: Tire and Wheel Gallery - Post Yours Here!
That looks good. The 35s look the right size. Now I want 35s...
Justin
2001 Van Haus E350 EB 7.3L Quadvan 4X4
1999 Sportsmobile E150 - SOLD
2002 Sportsmobile RB50 7.3L 4X4 - SOLD
dokaman is offline   Reply With Quote
Old 10-07-2015, 12:29 PM   #82
Where did you get these? And are they 16x8? What offset?
ecmccarthy is offline   Reply With Quote
Old 10-08-2015, 08:55 AM   #83
If you are asking about mine.
They are 17x9 ATX rims 4.5" bs -12 offset
I got them locally and paid more than if I sourced them online, but was able to get them mounted balanced and know where to go if I have any problems.
cjken is offline   Reply With Quote
Old 10-08-2015, 09:06 AM   #84
alta825's Avatar
Liking the looks of those rims cjken - getting ready to order new rims/tires from the local tire dealer and the Mojave 2 is on the short list.
Quick ? for the masses regarding the Cooper ST Maxx's - getting ready to pull the trigger on a set of 315/70/17s and I've always gone w/ an E Rated tire for the load rating. However, the Maxx in 315/70/17 is only D Rated but it has the identical 3195lb rating as the E Rated BFG/Toyo's etc...
Thoughts?? Rig is 10,500lbs....
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
Old 10-08-2015, 12:39 PM   #85
275/70/18 Toyo ATII on 18x9 ProComp rims with +5 Backspacing. Did I mess up by trusting the guys at the local shop? They said that +5 BS = ~-12MM offset. After doing more research, it sounds like the +5 went the other direction. Any help clarifying is appreciated.
bb121 is offline   Reply With Quote
Old 10-08-2015, 08:44 PM   #86
I believe that 5" bs on a 9" rim will be around 0 offset. You will probably be ok rubbing wise with 275's and that setup.
Old 10-09-2015, 01:46 PM   #87
Originally Posted by schluchtenflitzer
Here my 2001 with 37" BFG-MT on 9" Mickey Thompson
about 3-4 inch lift as i want to keep the van as low as possible so
front and rear fender had to been cut to prevent the tires scratching while twisting
Love the look of the MT's, and your van. I've been told that MT only makes rims with a 125.19mm center bore. Is that what you have or am I getting misinformation. I have a 2004 SMB conversion and as I measure my existing rims, they have a 130mm center bore. Where did you get yours?
Old 10-12-2015, 05:37 PM   #88
LastBlackE350's Avatar
Mickey Thompson Deegan 38 Pro 2's, 18" x 9", -12 offset with 4.5" backspacing and 285/65-18 BGF KO2's.
LastBlackE350 is offline   Reply With Quote
Old 10-29-2015, 01:48 PM   #89
Jolly705's Avatar
TR with 265/70/17 Gladiator QR900 MT
Weekends are meant for being off road!
Jolly705 is offline   Reply With Quote
Old 11-06-2015, 02:38 PM   #90
My van came from FamVans with 285/55/20" tires that have worked fine for beach running and light off road general camping. Now that it's time for a new set of tires, what are the disadvantages to replacing them with the same size Coopers?
I don't see many of you running anything this large and no one with such a low sidewall profile. Do I need to change out the wheels too to get back to a more serious off road set up?
Tomboy is offline   Reply With Quote
