Old 07-29-2022, 07:42 AM   #11
Kibo, thank you for this detail and for your efforts to help me and research #s. That’s super kinds of you! What you describe here is spot on to what is happening. [In stock form, this bracket wiggled around enough that the cable pull from the handle was barely enough to open the door. Interestingly, there was a hole in the middle of the bracket--so I added a screw (green circle below), and this solved the issue:]
The difference is the access on the 60 (with power locks) is only possible by drilling out the rivets. Even if it was screwed in I would not be able to reach it.
Curious…how are you identifying the OEM part numbers? Do you have access to some schematic I could find? Regardless THANKS.
Clarkboulder is offline   Reply With Quote
Old 07-29-2022, 09:06 AM   #12
Ford Parts Giant is a great resource for OEM Part Numbers. While I hesitate suggesting RockAuto they are sometimes helpful, at least identifying Ford part numbers.
Old 07-29-2022, 11:52 AM   #13
Kibo's Avatar
That makes sense. Are you concerned that you won't be able to reinstall it after drilling out the rivets? It's not as scary as it may seem. Window regulators are often riveted in place on modern vehicles, so I've had to do this sort of thing before. Just make sure you have a replacement handle, rivets, and rivet tool handy before you pull things apart.
A number of Ford dealerships have an online parts ordering system that is linked directly to the system their parts department uses. This is nice because you can use the diagrams to identify the correct part to order, plus it will show the latest/greatest PN if it has been superceded (case in point, spark plug recommendations for the V10). I have found this one pretty convenient to use:
Lakeland Ford Online Parts
Once you've entered your vehicle details you can look up parts using diagrams, check compatibility, and identify the OEM PN. For instance, your search for a door handle should have led you here:
60 Barn Door Handle (8C2Z1526604BD)
I've bought from this vendor several times as well, but of course once you have the PN you can search for the best deal. Ford Parts Giant as recommended by JWA often has the lowest price, just watch out because they make up for it by charging more for S&H than most places.
Things get a bit trickier when looking for OEM parts that aren't stock on an E-series (i.e. 4WD). If you have a 4WD setup and need parts related to the front axle, you'll have to trick it by entering an appropriate vehicle type and know what parts are or aren't compatible. For example, my Quigley uses a front axle from a 2010 F350 so I can look up the PNs for the tie rods, but the panhard bar is custom because the frame rails on an E-series are narrower than an F-series (plus it's affected by lift, whether you have a drop bracket, 4-link arms, and so on).
Old 07-29-2022, 01:45 PM   #14
Annie O's Avatar
Good info, another thought
Looks like great info above re the cables etc. I experienced similar condition this year on my rear barn doors, long story short bolts needing drilling/replacing in latch but also the HINGE was worn and causing faulty door alignment (cause of wear on latch?)
Chicken/egg don’t forget to consider whole door alignment
(Part seems like a lesser alloy than original Ford steel but hey it’s fixed for now)
Annie O is offline   Reply With Quote
