Are you able to attach some pictures of the undercarriage?
Any evidence of fluid leaks under the van?
Can you provide the date the 4x4 U-Joint conversion was done?
Did you perform the pop-top conversion to the roof?
*Hard to tell from the pictures, so can you clarify if all the 'black stuff' both inside and outside on the pop-top canvas is mold or not?
*Also looks like where the canvas attaches to the roof is pulling away (it doesn't look like a good seal), is this the case?
You mentioned a water tank mounted under the frame rail - does the interior have a sink? If not, can you explain how the water system works for the user?
You mention solar & house batteries; how large are the batteries & what type? How large is the panel array on the roof? and which solar controller is being utilized?
*From the pic's I do not see any outlets (120 or 12v) mounted in the interior build - Do you have these available and hooked to the house bank?
FYI: the more detail you provide on your listing, the less time you'll have to contend with answering the same question(s) for all the people inquiring.
