It’s totally worth it. You will have to make a plate that fits the Ford seat bolt pattern with a hole in the center to clear the electronics buried under the drivers seat. I used 1/4 thick. Weld that onto the universal seat bracket that came with the seat. Give it some tilt back. The other mod is the airbag equipment on the seatbelt receiver. Mine just bolted on to the seat. The seat held pressure so the compressor did not have to be on all the time. There is plenty of vertical room and if you shop around some seats are lower profile.
