Old 10-15-2019, 09:28 PM   #1
KTMRIDER's Avatar
WTB - Xantrex Prosine 2.0 Remote Panel
The Remote display panel on my Xantrex Prosine 2.0 inverter shows memory fault. Can’t seem to find one for sale anymore so hoping someone may have one laying around they don’t need.
Also open to someone local letting me swing by and me hooking their panel up to my inverter so I can set it to work without the panel.
Thanks
Eric
KTMRIDER is offline   Reply With Quote
Old 10-16-2019, 07:18 AM   #2
BrianW's Avatar
Can’t you just unplug the remote and use the controls on the inverter itself? Most inverters are designed to work airborne remote as usually it’s an option.
Old 10-16-2019, 05:51 PM   #3
KTMRIDER's Avatar
Thanks for the reply. The Prosine 2.0 has that option but you have to have activated it manually through the remote. I have tried inverting with something plugged in but it didn’t work. The previous owner had the unit repaired at one point but the panel is bad so I can’t confirm it works and panels seem to be hard to come by.
Old 11-18-2019, 05:46 AM   #4
KTMRIDER's Avatar
Bump. Still looking to buy a used panel or use someone’s to set the settings on mine.
Thanks
Old 11-18-2019, 06:44 AM   #5
BrianW's Avatar
I assume you looked on EBay? I found a panel for my older Trace Engineering (aka Xantrex) on there something years ago.
Old 11-19-2019, 05:34 AM   #6
KTMRIDER's Avatar
Yes I have been watching eBay and Craigslist. A few complete non-working units with the panel have been for sale but haven’t received a response when asking if they would sell just the panel and if the panel works.
Thanks
Old 05-02-2020, 12:56 PM   #7
KTMRIDER's Avatar
Bump...still looking for a panel. Or someone that has one in so cal we can hook to mine to see if it works and change settings to manual no panel needed.
Thanks
Eric
Old 05-02-2020, 11:37 PM   #8
Eric did you try replacing the data cable first?
Old 05-03-2020, 01:33 PM   #9
KTMRIDER's Avatar
Hi Dave,
I did try the cable from my Magnum 2000 unit I installed in my last van and it still showed the same error. I had a receipt that showed the previous owner had it fixed once and I think replaced at one time so hoping it works but that panel is hard to find for some reason. Surprising since so many were sold.
Thanks for the idea.
Eric
Old 11-23-2020, 05:49 PM   #10
Same problem, can we work together?
Hi KTM Rider
I've got the same panel with the same error, maybe this is a common failure for these and that's why they are hard to find.
I repair electronics for a living so I think I know what's wrong. There is a small memory IC right beside the CPU that I think is corrupted. I removed mine, copied it's contents to a brand new IC and soldered it onto the board but got the same fault. I think if I could get a hold of a working unit and read the memory IC on it I could write it to mine and yours and get them working again.
You mentioned that you had seen Prosine 2.0s for sale, if you can send me links I'll buy one of them and try my theory out, if it works on mine I can fix yours as well.
Jeff
JayArr is offline   Reply With Quote
