Old 04-08-2014, 09:09 PM   #1411
Re: What did you do to your SMB today?
Originally Posted by geoffff
Well not really today, but going through some old photos.... Here's a quick fix I made to stop those fridge door shelves from popping off when they're full of heavy stuff.
I've been dealing with this problem for 10 years, and two fridges. Fixed with 4 drilled holes and 4 screws.
-- Geoff
Anyone know an on-line source for those plastic fridge door shelves? Seems mine has suffered fragmentation
2011 VW TDI Golf for hwy fun
Old 04-09-2014, 08:54 AM   #1412
geoffff's Avatar
For my fridge, it looks like it might be part 422508810, so try googling Norcold 422508810. But make sure it's compatible with your fridge.
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 04-19-2014, 02:19 AM   #1413
Zeta's Avatar
Replaced my pyrometer and transmission temperature gauges. The pyrometer's needle had begun to stick, act erratically and wouldn't read over 1000°. I went with Auto Meter's factory Ford matching units. They look very sharp, especially at night.
The old gauges were also Auto Meter, so I figured I would just be able to plug the new ones in. No such luck. I had to run harnesses for both of them--what fun!
Very happy with the results. Still have trouble getting over 1000° though, with my PowerMax turbo and custom tune it just runs too darn well.
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 04-19-2014, 01:41 PM   #1414
Finally bit the bullet and got the insulated cover for my Dometic cool/freeze. Installed it and hope it helps shorten run times for my compressor.
stanw909 is offline   Reply With Quote
Old 04-29-2014, 03:31 PM   #1415
ProfessorPaddle's Avatar
Did this a few days ago but still feel like it is fresh in my mind.
Upgraded to the V8 SSBC Big Brakes with Drilled and Slotted Rotors.
Best addition ever? .... No probably not, but they do add significant stopping power thar be no question about that.
2006 E350 6.0L (VanDelizer)
1986 Vanagon Syncro 3.3L SVX (battleCat)
1984 Vanagon GL (Chuckie)
1980 Vanagon Westy (Taylor)
ProfessorPaddle is offline   Reply With Quote
Old 04-29-2014, 04:42 PM   #1416
Zeta's Avatar
Cool. What wheels are you using? 16"?
Z
'06 RB50 SMB Diesel
Old 04-29-2014, 07:15 PM   #1417
larrie's Avatar
Finely go to around to putting the clean dishes back in the van from last months trip. When I did that I found that ants had move in and were nibbling on a piece of chocolate hat I had left on the counter. Oops.
Larrie
Old 05-01-2014, 02:27 PM   #1418
New BPD EGR Cooler, New Ford Oil Cooler, New Fan Clutch. Last month New Michelin tires. Now I'm ready to go to Alaska!
Old 05-01-2014, 09:27 PM   #1419
MadScience's Avatar
I finally changed my fuel filter (v10 - gas) for the first time. I don't know if/when it was changed previous to me owning the van, I put ~ 15k on it.
This is the residue from draining the filter into a previously clean (slightly greasy) oil drain pan:
Silt, metal shavings and a couple small rocks (large sand grains really). Yikes! Good to know the filter was doing it's job.
I cut up the old filter, and it's pretty brown and waxy.
The combination of the places I take this thing, and the fact that it gets 12 mpg at best, means that I've gotten fuel all sorts of places that I might have skipped with other cars. I'll do another change in 12 months / 5k miles and will see how bad that looks.
I have not driven the van yet (and may not for a couple of days), but it did fire up on the second try (re-priming obviously) and it seems to be running fine. No codes or any unhappy signs due to the momentary lack of fuel pressure.
Old 05-01-2014, 10:32 PM   #1420
MadScience's Avatar
Wow! Those look sweet!
Vanny Devito
dick
Clyde
ormtnbiker
