I would monitor these:
Pair EGT with RPM and Boost
Pair ECT with EOT and Trans Temp
FICM voltage
ICP Pressure
Air Intake (simply because it gives me an idea on how hot it gets under the hood when i'm not pushing air through the front grill - it's alarming how hot it can get!).
Alarm set points are a frame of mine; would you rather they acknowledge you're approaching an area you'd prefer not achieve, or just sound off when you get to your finish line?
Personally, I would rather have some forewarning, allowing some time to reevaluate and the opportunity to change tactics. I wouldn't set the alarms to go off too prematurely - that would just get annoying.
For Me: ECT would be 225, EOT 225, Trans Temp 210, FICM 48, EGT's 1200, ICP 550, Air intake 150...when any of these readings hit my target, I know its not the end of the world but instead informs me from that point on to monitor the offender(s).
