Old 01-01-2009, 11:29 AM   #11
Hey, scalf77..I just checked and I have a sure power battery separator...I'm at a loss with this thing so I'll check out the link. Thanks
2000 E-350, 7.3 Power Stroke Diesel. 4x4. Loaded. "The Big Gray Whale"
1982 Mercedes 300D. WVO, SVO and Biodiesel for the last 30,000 + miles. (my 600 mile a week commuter).
Veg Hed is offline   Reply With Quote
Old 01-02-2009, 09:12 AM   #12
Veg Head just be aware that Sure Power makes an isolator and a separator. Isolators usually have big finned aluminum heat sinks and look completely different than their counterparts. Maybe the last owner changed it to a separator.
http://www.surepower.com/isolator.html
http://www.surepower.com/separator.html
Dave.
Old 10-28-2010, 04:42 PM   #13
Re: No volts to coach batteries when running or idling........
I have had problems with the seperator also. Several times it didn't switch over to charge the house batteries after starting the engine. If I went back and gave it a good smack, it switched over. SMB Indy also suggested removing the ground wire and reattaching it. Seemed to help at the time, but the problem returned. They recently replaced the seperator, so I hope it is solved.
