Old 02-27-2024, 12:12 PM   #11
mikracer's Avatar
Lynx levelers have worked well for me, but if you don't have 4x4 and you need to level the front , it can be difficult because the front tires just push the blocks without 4x4.
Old 02-27-2024, 02:15 PM   #12
Twoxentrix's Avatar
Originally Posted by doublevan2 View Post
TwoXentrix -- where do you store your pads ?
Russ, I have the older style Aluminess box which has the tube rail welded around the top (prevents stuff stored up there from slipping off). I carry 2 Scepter Runts (one on each outside edge) and 5 of the rubber leveling pads between them - the 6th pad I keep inside the van sandwiched between 2 pelican cases which hold most of my recovery gear.
With this added weight on the box, and the Honda EU2200 generator I store inside the box, I also added 2 pairs of the Aluminess shim's which are mounted under 4 points of contact (between the top of the rear bumper and the bottom of the swing-out tube support) - this way most of the weight it removed from the swing arm welds & pivot points. Haven't had any issues with this set-up, and I check the welds relatively frequently for cracks.
*I use a pair of the shim's on the Tire swing arm for the same reasons.
As back-up, I apply a safety cable which secures the swing arm's to the bumper in the event something gives while traveling on the road (if either swing arm breaks loose I would rather drag it until I stop than have a vehicle behind me run into one after its fallen off...in turn creating a potential disaster)
Old 02-27-2024, 03:48 PM   #13
I use GoTreads They can be folded in different ways for different heights to pull up on and they make great traction pads when needed
NoData is offline   Reply With Quote
Old 02-27-2024, 04:17 PM   #14
WhitH's Avatar
Second the GoTreads if you are going to buy something. They can level and get you unstuck. I'd just use rocks or whatever you can find around for the most part, but if you are going to buy and carry something it makes the most sense to have an item that can do more than just level you out at camp.
Sold 2005 E350 Chateau
Old 02-28-2024, 03:24 PM   #15
Thats nearly exactly what I did, but I also welded gussets to the pivots, and have a chain from the bottom of the box to the trailer hitch with a cam lock that pulls the box down onto the pads when latched. I carry 15 gallons of fuel on top and a Honda gen inside. I've had the box swing open accidentally while driving with no issues, so I'm guessing your fine too.
Old 02-28-2024, 06:31 PM   #16
Twoxentrix's Avatar
Originally Posted by arctictraveller View Post
... and have a chain from the bottom of the box to the trailer hitch with a cam lock that pulls the box down onto the pads when latched.
That's an interesting approach! I can see how that would keep all stress off the swing arms since it also alleviates any up-travel . No rush, but at some point I would love to see a pic of that set-up. Also assume you have some sort of backing plate on the inside of the box where chain attaches???
Thanks for sharing arctic.
Old 03-03-2024, 10:31 AM   #17
They aren’t cheap but I’m loving my inflatable leveler
Kelp is offline   Reply With Quote
Old 03-03-2024, 01:57 PM   #18
I have used my GoTreds for years now and I really like them. They are compact, easily cleanable, and easily stored away.
Queenie is offline   Reply With Quote
Old 03-04-2024, 03:01 PM   #19
CDACamper's Avatar
I made leveling blocks exactly like the ones in this article. https://www.rv.com/archive/multi-use-leveling-blocks/ They work great and were free because I had the 2x6 and pvc laying around. I store them in the basement storage. I also use my traction boards as additional levelers if needed.
______________________________
2001 E-350 V10 EB50 Penthouse
4.56 gears w/ARB Rear Locker
4X4 Quigley
Agile RIP
CDACamper is offline   Reply With Quote
Old Yesterday, 03:24 PM   #20
DesertSMB's Avatar
Originally Posted by Orv View Post
I've used a few different systems, all of which work, but I wanted to point out that the nemesis of all plastic levelers is rocks. If you catch a rock under the leveler the point stress will break the plastic. You have to be really careful to clear or avoid any stones that stick up.
I use some of the Lego like leveler blocks. I too had problems when I put them directly on the ground. So I cut two pieces of 3/4 inch plywood just a bit bigger than two of the blocks. I use those under the blocks so they remove the problem of point loads. I don't think I've ever needed to do more the two points for leveling.
By the way I use one of those step stool tool boxes to store the blocks. I don't have the tray that usually comes with them and cut out the ribs that would support the tray.
Chris/Bev
2012 E350 EB50 V10 Cruiser Top
Sportsmobile 4WD Conversion
DesertSMB is offline   Reply With Quote
