I am building a ground up Galley for my van with a 36" kitchen cabinet as the base. I found a "bartenders" 15" sink at Lowes and there is plenty of room in the cabinent for tanks and pumps. BUT, I had a momentary bout of curriosity. Anyone seen a gravity feed water system?
I have a porcelain water dispenser I do not use. Simmilar to these
What if I put a fitting on the dispensor instead of the spigot and plumbed it into the sinks cold faucet from there? Would eliminate pumps and switches for water, and flow would be controled via the normal tap handle.
I would have to find a place, at least on top of the counter, to mount the 3 gallon reservoir and dispensor but at least it would make water level checks easy and refills as easy as flipping on a new bottle. Plus it could free up space under the sink for supplies or my battery.
I also thought of mounting a flat tank against my roof for more pressure.
