Old 03-07-2021, 02:29 PM   #11
Clean install. What is that bracket or hinge at the end of your metal frame? Looks like it’s to allow a seat to fold forward?
2003 Astro AWD
2005 Tacoma Access cab 4x4
Old 03-07-2021, 05:21 PM   #12
Thx... VW bus zero clearance type hinges for bench to bed conversion. I needed an under rear bed platform height greater than the sportsmobile type hinges provided.
sailincoot is offline   Reply With Quote
Old 03-07-2021, 08:57 PM   #13
I’ve read a good deal about water tank discussion over the years and disagree with large tanks (unless you’ve got a big RV someone services). My experience (…40 years+) of water tanks has come down to “What’s the easiest way to clean one?” If you get any water from a municipal or private well system that is not filtered to 1µm (1 Micron) you will eventually find a slimy film of material on the bottom of your storage container. How much is too much? I don’t know. But I find any a little disturbing. So I use 2.5G jugs with a 5” Dia. access lid and its own flip to twist handle spout. It's very easy to reach in and wipe around with some sort of cleaner. Another point is the convenience of carrying a balanced load (i.e., 2 smaller ones equal to 5G.) any significant distance from a faucet or a stream (Yes, I pump filter and treat the water). It's well worth it. Lugging 5 G. in a single container is doable, but I’m talking about preferences. So, easy cleaning, portable, and small enough to set-up outside on a table all make me choose the 2.5 Gallon container.
PS. I’ve bought 6 on Amazon that have been traveling for about 2 years -1 leaked. The good ones have small air valves in the wide lid. Whatever you do, don’t buy the cheapest ones. (That goes without saying, huh.)
Stewbie is offline   Reply With Quote
Old 03-07-2021, 11:33 PM   #14
Originally Posted by sailincoot View Post
I used the driver side version with the back open. I wanted to allow room for the factory ac/heating. Modified heater and ac outlet so I could re-route through cabinets.
Is that the modified outlet? Do you have a 'before' pic?
Thanks do you have a link for those?
2003 Astro AWD
Old 03-08-2021, 07:34 AM   #15
Has anyone installed this tank in a E series van?
Old 03-08-2021, 07:42 AM   #16
I used these:
https://www.busdepot.com/98553/
They stand about 3 inches taller when deployed as bed. That allowed me to have a higher rear pad height for storage.
Sorry, no picture of heater outlet before I modified.
quigley
4x4Ken
Zengi
Amy V
