Old 02-15-2011, 01:12 PM   #1
Anyone trashing their Norcold? Need hinge bracket and screw
I wish I'd thought of this when deminimis removed his, but my left hand hinge upper bracket (or right hand hinge lower) is stripped and was drilled out by the previous owner. Since the "screw" is a specialty item with a built in bushing, the replacement bolt is rather sloppy and I realized I should just replace it.
Any chance someone has this lying around? How about Norcold parts sources for hardware?
Old 02-15-2011, 01:42 PM   #2
Re: Anyone trashing their Norcold? Need hinge bracket and screw
It's a DE0041 and the part is 619336 Hinge-Cabinet/3 Point/Top LH/Btm RH/Panel/Black
http://www.thetford.com/HOME/PARTS/Norc ... fault.aspx
Old 02-17-2011, 08:58 PM   #3
rnj
rnj's Avatar
I ordered door gasket & latch for my 1995 DE541 from pplmotorhomes.
http://www.pplmotorhomes.com/parts/rv-r ... -instr.htm
I did a search on your part number.
________________________________________
HINGE-3 POINT/BLACK/TOP LH/BTM
Price: $19.39
You can also order the bushing & other small parts
BUSHING (DOOR HINGE)
Price: $1.39
Randy
1995 E250 2x SMB White Contempo Top Custom SMB Interior 5.8L (351) 69K miles
Added Propane Tank & Propex HS2800/20 Gal Fresh inside/20 gal gray underneath behind axle
2.8K Onan/Porti Potti Shower Area/110V Digital Oil filled Electric Radiator Heater/Dynaglo for backup
Hankook Dynapro ATs 225/75-16 LRE
New to me 10/2008 - 2nd owner
rnj is offline   Reply With Quote
Old 02-28-2011, 04:16 PM   #4
Ozrockrat's Avatar
Let me check when I get home later in the week. I have a Norcold I pulled from my van but from memory the hinge points come from the top??? If its the same you can have them all. The oscillator is gone and the door is twisted so for me it is stuffed.
1998 E350 Quigley Diesel Ambulance Conversion For Sale
1962 R60/2 BMW with Ural sidecar.
2000 K1200LT
2001 Dakar 650
2000 Dakar 650
TW 200 pit pig.
Ozrockrat is offline   Reply With Quote
Old 03-01-2011, 04:14 PM   #5
Got one already, thanks though.
You should strip yours and ebay your parts- these things are insane- $6 for a screw? Bushing separate?
