Originally Posted by EMrider
On my last two camping trips with the kids, the weather has been cold enough that I need to run the suburban propane heater intermittently throughout the night.
This past weekend, we were up at Rock Creek near Mammoth and overnite temps got below 32deg.
At bedtime (9pm ish) I set the thermostat on a low temp setting and that usually causes the heater to cycle on 4-5 times for 30-45min each cycle during the night.
While this routine leaves the inside of the van warm and comfy, on both recent overnighters the CO2 sensor alarm has gone off early in the morning (between 5am and 6am). Obviously, I want the sensor to function properly for safety reasons. But I'm curious what I can do so that it does not go off at all?
Should I open one of the windows for ventilation (in the penthouse or down below)? On cold nights I normally have all upper and lower windows shut to retain heat. But with 3-4 people alseep inside, lack of ventilation could obviously be a factor. The suburban vents to the outside of the van so I assume that is not a factor..........
I know many others here camp in cold weather and use the suburban heaters. Any tips to avoid setting off the CO2 alarm would be appreciated. And FWIW, the CO2 alarm is loud and does its job well.
Thanks
Rob
And totally off-topic, it was a quasi SMB convention up in Mammoth last weekend. On Saturday we spotted 8 different rigs around town.
Quick update here......
I've run the heater for two nights in a row. Top down, all windows closed and pretty much zero ventilation. The CO sensor I put inside the van has read 0ppm CO max each morning.
That is comforting, but it still leaves me in the dark about what set off the CO sensor in the van?
I'll test the unit a few more times just to be safe and will now always have a backup CO sensor with an actual digital readout on COppm with me when camping.
I'm thinking that maybe the 'problem' is the ignition process when the furnace kicks on. Running continuously seems to be fine. The two times I've had a CO alarm sound followed a 6-8 hour time period where the furnace cycled on and off at least 10-15 times. Given how slowly this thing sips propane, I'll just set the temp higher so it cycles on and off less often.
R
