Old 03-08-2018, 03:14 PM   #1
TheVagabondMBA's Avatar
Front bench in e350?
I've tried searching a few sites and have not yet found anything on this.
Has anyone put a bench seat in the front? Trying to find a solution for a second sleeping spot in our DIY build and we got to thinking a front folding bench might be the solution. We aren't concerned with being able to walk-through from the cab to the rear as we already have stuff stored by the doghouse (my dog's bed to be exact) and we're already contemplating closing off the cab when we build our overhead storage. Just wondering if anyone has a bench up front in their rig.
Thanks!
TheVagabondMBA is offline   Reply With Quote
Old 03-12-2018, 04:39 AM   #2
Felt a bit bad your post went unanswered VB so here's an idea or two........
I've not seen a front bench seat in any domestic van built in the past 50 years so that says something. The engines have always been place where their intrusion into the front seating area is unavoidable. Anyone here remember those huge doghouses smack dab in between the front seats?
Rather than modifying the van to accommodate a full-time front bench seat consider the typical Ford center console does remove which gains 8"-12" of space---naturally the engine cover can't be removed and the van still driven.
With the center console removed some sort of "bridge" between the front seats could be made and installed when the extra sleeping area is needed. You'd still have the steering wheel in place, a tilt function helping a bit.
That's all I've got--not much but maybe helpful in your creative process?
Old 03-12-2018, 05:57 AM   #3
Have you considered installing swivels for the driver and passenger? With the seats turned and then pushed “back” towards the front of the van you open up that area quite a bit and may be able to span something over the seat cushions. It’s not quite as roomy as a fold down bench if you could even find one. I suspect you may need to look at different model van and adapt it to yours with belts, etc. I heard of an Astro fold down seat for the rears, not driver.
Smoker is offline   Reply With Quote
Old 03-12-2018, 09:47 AM   #4
Thank you both for the replies.
My concern was being able to remove the doghouse and still have access to the engine. I don't think it would be possible with the bench. I found someone local who was parting out an old Club Wagon and he had a nice red folding bench. I went to check it out and take some measurements of where it would bolt up, how wide it was, etc. Based on my measurements I don't think it would be possible. You could definitely fit it in there, but you'd have no access to work on the motor.
I think swivel seats with a foldable/removable platform is the best option. Either way, the OEM seats that are in my van need to be replaced. After 6 days on the road with them, my butt and back were hating me.
www.snakeandtherabbit.com
Old 03-12-2018, 09:56 AM   #5
I hear the Scheel-Mann seats are super comfy. Rather expensive, but you can't put a price on comfort and reduction of pain. MG sells them and has designed bases. Might even swivel.
Old 03-13-2018, 05:23 AM   #6
Were I do go with the Scheel-Mann seats I'd definitely keep the original seats in case the van was ever sold----exchange the better seats for the OEM's in storage. Or perhaps the new owner would pay a bit more for the Scheel-Mann?
Also keep in mind the stock Ford seats can be renewed with replacement foam pads available from Ford. Personally I don't find the OEM versions all that uncomfortable.
Another aspect is stock seats from about '97 thru 2003 seem "better", built from materials better suited for longer term use. Having a few newer seats repaired its quite obvious the newer they are the cheaper they're built.
Also seat bottoms from left and right sides can be swapped out without any issues.
Old 03-13-2018, 08:58 AM   #7
rallypanam's Avatar
http://www.sportsmobileforum.com/for...bed-10903.html
Old 03-13-2018, 09:18 AM   #8
Originally Posted by rallypanam View Post
I saw that one too. I was really hoping the bench would work. The idea of having to build and store a platform like that for the front seats seems like a waste of storage space. I'm sure I can come up with something
Old 07-24-2018, 07:20 PM   #9
MG? Im looking to replace my econoline front seats and these tings look perfect
seal is offline   Reply With Quote
Old 07-25-2018, 04:45 AM   #10
shenrie's Avatar
^^^ his screen name on here is mgmetalworks. This is his website: https://expovans.com
Betsy
Dave&Di
PigPen
velo47
