Old 07-08-2020, 02:10 PM   #1
Need to clean pop top
I have a 1995 Sportsmobile and pop top is badly stained from live oak trees.
Anyone know of a good way to clean it other than power washing.
apprill is offline   Reply With Quote
Old 07-08-2020, 02:47 PM   #2
BrianW's Avatar
Scrub brush and bleach if it's stained, I guess, is the other option. But I used a power washer on mine and it worked great. Any reason you don't want to do that?
Old 07-08-2020, 03:11 PM   #3
I hired someone who used a gas power washer and he took some of the paint off the van body. Would an electric power washer do the job? I am willing to purchase one if powerful enough. If so any recommendations?
Old 07-08-2020, 03:12 PM   #4
paint it with monstaliner!!!
https://www.sportsmobileforum.com/fo...se-9109-3.html
cleaning depends on the condition of the clear coat and fiberglass top.
found this by searching google and it might help
Chris
2006 E350 EB 4x4 SMB: 6.0L-5R110-Atlas-D60-D60FF-yada-yada-yada
Old 07-08-2020, 03:28 PM   #5
I used a credit card to scrape moss off mine. Took about 4 hours to do it, but came out pretty good. Pressure washing works better if you have a balcony from which you can wash it.
Old 07-08-2020, 05:07 PM   #6
Thanks great help everyone! I will try bleach and ordered the Hull boat cleaner.
Old 07-08-2020, 08:22 PM   #7
BrianW's Avatar
This is what I have and it worked great on the top: https://www.lowes.com/pd/Greenworks-...her/1000604813
I also have a high end professional power washer with like a bazillion psi (with the right tip it can almost cut through concrete) and I wouldn’t get close to a vehicle with that.
Old 07-09-2020, 07:44 AM   #8
Great will give it a try!
Old 07-23-2020, 12:48 PM   #9
I've had good results with a he tile cleaner soft scrub.
Prifly is offline   Reply With Quote
Old 07-23-2020, 01:54 PM   #10
pjpvi's Avatar
Not exactly what you are asking, but just to pass along for what it's worth I recently have found that ProtectAll works exceptionally well on the PH top windows. Mine had gotten pretty "foggy" over the years and I just used this stuff on them after reading about it somewhere else and it worked fantastic. It also makes the powder coated Aluminess bumpers look great again.
Phil
- 2005 EB50 6.0PSD - SMB 4x4
