Old 07-09-2020, 06:34 AM   #331
I need to purchase a front awning bracket for a E-150
If anyone has one, please let me know.
Ray, I also sent you a PM about this.
Thanks all,
Harold
teerhb is offline   Reply With Quote
Old 07-11-2020, 07:30 PM   #332
jeff00seattle's Avatar
Is the Fiamma F45S awning still preferred awning?
If so, then I would be into the Fiamma gutter mount bracket set.
Thank you.
Jeff in Seattle
2001 Ford E-250 RB50
jeff00seattle is offline   Reply With Quote
Old 07-12-2020, 08:19 AM   #333
I no longer need to purchase that front bracket.
Thanks everyone for the help,
Harold
Old 07-12-2020, 08:40 AM   #334
I have a Ford E250, SMB RB50 Penthouse.
Considering the purchase of Fiamma F45s 300
1. Confirming, the brackets you are selling for mount aforementioned configuration?
2. Are you still taking orders?
3. What is the primary reason I should purchase your brackets over the AWNING BRACKET FOR FIAMMA - SPORTSMOBILE PENTHOUSE - FORD/GM on the Sportsmobile Store site?
Thank you
Jeff in Seattle
Old 07-12-2020, 08:43 AM   #335
1der's Avatar
Thank you.
F45s 10ft (3 meter) is a great awning solution. I think you reviewed the Which Awning thread.ARB/CVT has its place, too. Really depends on budget and expected usage.
Either way, if you have a pop top and want an awning, then the gutter mount brackets will be necessary. The SMB brackets require drilling holes into the body of your van. Mine require no drilling.
Yes, still taking orders for this upcoming batch.
Have you lined up an F45s?
Old 07-12-2020, 04:39 PM   #336
Thank you for your time today. PayPal payment for awning brackets has been sent. ABS 1/16 inch sheet (8' x 8.5'') has been ordered via Tap Plastics. If you have mentioned 8' of "gasket" for that sheet, that would be great. Also, what LED strip and attachment did you add your awning again? Thank you again.
Jeff in Seattle
Old 07-20-2020, 11:57 AM   #337
PNWVAN's Avatar
So these will work with either ARB or Fiamma?
PNWVAN is offline   Reply With Quote
Old 07-20-2020, 12:23 PM   #338
1der's Avatar
Correct. The brackets have a bend at the upper edge that accommodates the Fiamma mounting plate which has a hook. The Fiamma hooks over this bend.
The ARB has a flat mounting surface with twi slots for bolt heads to slide into. This flat surface will bolt against the face of the bracket.
fwiw - In the PNW I recommend the Fiamma due to rain and convenience.
Old 08-16-2020, 04:02 PM   #339
Any idea when the next batch will be out? I’m going to need set for an ARB 2500
TCNorthwest is offline   Reply With Quote
Old 08-16-2020, 04:42 PM   #340
tedujam's Avatar
Same here. I've got a CCV top install scheduled for mid October.
tedujam is offline   Reply With Quote
MoMo
skyrat
undecided
JOELMUNOZ3
