Old 08-21-2020, 08:47 AM   #401
Exclamation Passenger Side Swivel
Hi Ray!
I definitely want a passenger swivel base for our 2014 Ford E350 Van!
I’m sorry to be late to the party but just discovered this thread while searching for your Talon Door Catch - would like one of those too
Please let me know if you can still accept my payment for this go round or if I need to wait for the next group purchase.
Thank you for coordinating this for all of us!
dscott2623 is offline   Reply With Quote
Old 08-26-2020, 10:52 PM   #402
1der's Avatar
Three Passenger seats left ready for shipping.
Looking at starting another group buy if enough interest. Target ship date is mid October. Pls let me know! Thxs!
Old 08-27-2020, 05:45 AM   #403
Just installed drivers yesterday a bit tight for armrest with scheel mann but once you figure out how it turns no problem
snowgroomer is offline   Reply With Quote
Old 08-28-2020, 07:04 PM   #404
Swivel seats left?
Am I understanding this as you have three still available and unclaimed. If so I'm interested.
mikewmay is offline   Reply With Quote
Old 08-29-2020, 07:37 AM   #405
1der's Avatar
Wiring: ( see post#151 this thread for more details and pics)
The wire is routed through the carpet/mat at the back edge of the swivel base floor plate.
"The sensor wires should be protected with split loom or something similar to prevent chaffing.
On the passenger side, the wire is run inboard of the swivel drum. On the driver side comes up through the whole in the lower section.
Disassemble the connector on the wires coming from the seat. (Others have cut the wires and re-spliced, just be careful and make sure the ignition is off and key removed). This is needed to feed the wires through the small hole in the upper plate of the swivel seat base. Mark the wires before disassembly so they can be put back in their correct positions.
Now you are ready to mount the seat to the swivel base upper section. The studs from the seat base tracks should line up with these holes. IF THEY DO NOT LINE UP – this means the tracks have moved independently from each other. Realign the tracks by pulling up on the seat slide adjustment bar and move the tracks so they are in proper alignment. Once the studs drop through the holes, secure the seat to the upper section of the swivel base with the original nuts.
Now we can finish the wiring - Pass the two wires through the hole in the upper plate and reassemble the wires into the connector housing."
Call/text me and I can help if needed.
Old 08-29-2020, 10:32 AM   #406
I'd like to have a passenger side swivel.
Kendel is offline   Reply With Quote
Old 08-29-2020, 01:32 PM   #407
1der's Avatar
Kendel - Welcome to the forum!
What zip are you looking at for shipment? I have one seat base left and waiting to here from the guy in front of you. If he does not respond or passes, it is your's.
I will get the info to you re; payment, etc. so you are already to go.
Cheers, Ray
Old 08-29-2020, 10:52 PM   #408
1der's Avatar
All done with this group buy, thank you to all who participated!!
Great news is multiple Scheel Mann seat installations were done, driver and passengers. These were mounted on the swivel seat bases using the adapters from SM made by ExpoVans.
Now we are onto mid October if enough interest. I have some interest already, so please get me zip codes and what you want. Thxs! Ray
Old 08-30-2020, 06:57 PM   #409
vandiesel's Avatar
Thanks Ray
Old 08-31-2020, 02:40 PM   #410
I'm interested in a driver and passenger zip 93311
TerryG is offline   Reply With Quote
