Originally Posted by 86Scotty
Thanks @BCam! Good info, especially since those are the two brands of lifepo's I own. I'll check out those videos.
I should have added that some, albeit more expensive, LiFePO4 batteries go the extra mile with built-in heaters to permit charging in low temperatures. This isn't a must-have for most people unless they spend a lot of time camping in extreme temperatures.
I've also watched Youtube reviews by other Youtubers and have yet to see one that puts LiFePO4 batteries through as rigorous testing as does Will Prowse. Most just determine that they appear to be well-built without a teardown and that they work OK with simple voltage and current readings.
Here's a good example of one of Will Prowse's reviews:
https://youtu.be/u7tt7ngfCAY?si=qi8e26zFYaMnAA3M
And a compilation of his budget battery recommendations, although I don't know how current it is, so check the links for current prices:
https://www.mobile-solarpower.com/li...batteries.html
