Old 06-07-2009, 08:18 AM   #1
SierraHawk's Avatar
'03 SMB w/broke TRACK BAR in Moab ...
I have an '03 Ford 5.4 SMB RB with Dynatrac front end. I broke the track bar on Saturday (6/6/09). It is Sunday (in Utah) and I need to know where I can get a replacement ASAP.
Would appreciate any info.
Thanks
SierraHawk is offline   Reply With Quote
Old 06-07-2009, 09:24 AM   #2
SMBDAD's Avatar
Re: '03 SMB w/broke TRACK BAR in Moab ...
Do you have a quigley or smb conversion? I have a 2001 quigley, and I believe that is one of the parts that I have to go through them for. Thats the only downfall to these vehicles is the CUSTOM aspect were parts can be specific and hard to get in a hurry!
2001 7.3 4x4 "Land Orca"
SMBDAD is offline   Reply With Quote
Old 06-07-2009, 09:28 AM   #3
scatter's Avatar
Quickest bet is to pull it off and get it welded up and then do a replacement (if needed) when you get home. Lots of folks have welders, so you should be able to find one by just asking around. Good luck....
Scatter
2007 RB50, 6.0
K1WGB
Old 06-07-2009, 09:40 AM   #4
Yep, have a local 4x4 shop in Moab weld it for a temp fix. Not sure if they do welding but I had a positive experience with the ASAP auto repair south of town on the east side of the hwy. SMB will be open on Monday and can probably overnight a replacement to you.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 06-07-2009, 09:58 AM   #5
SierraHawk's Avatar
Interestingly....the SMB website is down. I've called but the voice mail is turned off at Fresno. Is Heber still doing the Dynatrac conversion at Fresno?
Old 06-07-2009, 10:18 AM   #6
Yes he is. I spoke to him last week. Very helpful guy.
Desert Solitaire
2003 7.3L EB 4x4
Old 06-07-2009, 08:05 PM   #7
I just noticed from another post that you are in GJ now. Barney Brothers Off Road is pretty good at fixing issues and they treat their customers very well, might give them a try.
Desert Solitaire
2003 7.3L EB 4x4
Old 06-07-2009, 10:07 PM   #8
You sure don't hear about a lot of Quigley suspension failures or V10 engine problems.
One vote for the Quigley/V10 combo.
Old 06-15-2009, 04:45 AM   #9
SierraHawk's Avatar
Conclusion: Thanks for the replies. My SMB drove ok under 50 mph so I was able to get around. Because the ring on the track bar is relativly thin, I did not attempt to have it welded. The bolt on the dif side that it mounts to had become fused with the space. No matter what I did it would not come out. I had to cut the bolt w/sazall. I called Fresno SMB. They sent a new one with new bolts. Thanks to Peter and Heber I got it in 3 days.
Old 06-15-2009, 08:55 AM   #10
scatter's Avatar
All's well what end's well. Glad it worked out for you.
Scatter
2007 RB50, 6.0
K1WGB
Dodge
lugee
Ann the Van
Bongo
