Originally Posted by Otter
Skyrat, do you have a name/source for that lock?
I get everything right from Yakima.
Two of the items shown are on this page. But don't be afraid to give them a call and tell them what you need. Customer service is the best I have seen anywhere.
https://www.yakima.com/catalogsearch.../?q=hitch+bolt
I use the Hitch Lock to fit over the end of the Arm Lock Pin for the Hi-Lift.
It also fits over the end of the Hitch Bolt that I mounted to the Baja Box for the MaxTrax. The Hitch Bolt was used to mount the Yakima racks to a Hitch, allowing you to lock the rack to the hitch. Both are super useful if you can drill a hole or weld a bit. You can make almost anything to lock if you use a bit of imagination. I am also a big fan of the Lock Up on that page above. We use it to lock Kayaks to the bars on top.
EDIT: Here is a pic of the Hitch Bolt as originally purposed, mounting the hitch to the rack.
