Old 02-06-2019, 03:48 PM   #71
Michael, thanks for the overlay graphic. It clear that the 2013+ calipers don't fit the earlier axles, so short of changing out the knuckles an upgrade doesn't work. I'll look to get a1:3.73 ratio 2016 axle assembly since they didn't come with 4.10's. I will only be running running 33-34" tires and will have to decide which is best ratio to switch to. The ambulance is a 6.0L diesel. Any thoughts on an appropriate ratio?
JimGee is offline   Reply With Quote
Old 02-06-2019, 04:09 PM   #72
3.31 and 3.55 were the most common ratios in F-series trucks. I'd try to find the best deal on a '16 with one of those ratios and plan to change gearing. 4.10s or 4.30s would probably be close...would have to run the numbers through a calculator.
Old 02-06-2019, 08:10 PM   #73
mk216v's Avatar
www.car-part.com is your friend!
A vehicle’s worth is not what you put into it, but what it put into you.
2019 F350 SuperCrew flatbed composite camper
2018 Transit 130WB MR EcoBoost (SOLD)
2010 E350 RB V10 Cargo "unicorn" (SOLD)
2007 E350 4x4 "VANdiana Jones"(SOLD)
mk216v is offline   Reply With Quote
Old 02-08-2019, 09:38 AM   #74
Yes, it's a great resource. I'm searching there now.
Old 02-09-2019, 01:07 PM   #75
I bought a 2008 4.10 front axle on car-part.com with 43K kilometers
Here's a pic of the recipient vehicle leaving the Montreal area yesterday. The pickup was delayed over a week because of bad weather.
Old 02-09-2019, 01:26 PM   #76
Did you buy a DRW front axle? (I think so from your comment on the other forum)
and Do you plan on keeping it DRW?
Pinnacle Campers LLC, Boise Idaho
https://pinnaclecampers.com/
Brian94ht is offline   Reply With Quote
Old 02-09-2019, 02:01 PM   #77
Yes, it is a DRW front axle and I expect to keep the rear duallies, at least initially. May go to a rear SRW 10.5" later. I'm chewing on what to do about wheels and wheel bolt patterns. On my last Van I converted the stock rear axle lug bolt pattern from 8x6.5" to 8x170mm using quality adapters. I don't know yet if this is advisable or even possible on a heavy ambulance with duallies.
Old 02-09-2019, 02:13 PM   #78
My 2008 4:10 front axle prepped and ready for install...
My 2008 4:10 front axle prepped and ready for install...http://oi68.tinypic.com/2dwdmjt.jpg
http://oi66.tinypic.com/b5sncp.jpg
wild-kiwi is offline   Reply With Quote
Old 02-09-2019, 02:14 PM   #79
Don't know how to add pictures properly
Old 02-09-2019, 02:20 PM   #80
That looks really clean and well prepped.
