Old 05-19-2017, 09:29 AM   #21
1der's Avatar
Interesting about part numbers. The MOOG K80222 poly units I got from Felix (thank you!) worked perfectly in the 2000 Quigley V10. I had to cut the bushing sleeves to get those tack welded buggers out.
Used a piece of All Thread, nuts and large washers to press the poly bushings in most the way, then a BFH and a 2x4 to seat it the rest of the way. Worked well!
Note: if doing tie rods, it is way easier to deal with the swaybar bushings while the tie rods are out.
Old 06-12-2017, 03:17 PM   #22
TexGX's Avatar
Had my new bushings go bad. The shop working on it for me noticed the swaybar was angled too much. I will need a new spacer because of the RIP kit. Quick fix and should keep my bushings good for a long time.
TexGX
TexGX
2003 7.3PSD RB50 Quigley (The Yeti)
viewtopic.php?f=10&t=13220
2006 Casita (Makes it a three bedroom 1 and 1/2 bath)
TexGX is offline   Reply With Quote
