Old 06-04-2012, 07:44 AM   #1
Starting to suffer from 4x4 envy
Seems like this site is mostly about tuff off road rigs and my poor 2x4 Dodge just doesn't measure up. I still need to get into Hotel parking garages to carry in my musical equipment other wise I'd put a lift kit on it , Some gnarly tires and a roof rack over the cab with some big off road lights.Looks like you guys get to some great spots.I'll have to stick to black top and easy dirt roads for a while.Oh Well, Ce La Vie .
stanw909 is offline   Reply With Quote
Old 06-04-2012, 07:46 AM   #2
Re: Starting to suffer from 4x4 envy
Well maybe I could still get the gnarly tires when these wear out.
Old 06-04-2012, 08:19 AM   #3
twogone's Avatar
Seems like a second van is in order
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 06-04-2012, 11:20 AM   #4
I already have another conversion van that I need to sell as well as a Big motor home and Jeep cherokee 4x4 so I'm running out of room. And wife is running out of patience
Old 06-06-2012, 06:47 PM   #5
No worries Stan. I have the gnarly tires, rack, off road lights etc. Though it worries me to take such a expensive vehicle too far off road. 4x4 is a nice option for those times that you really need it but there are plenty good sites to see without 4 x 4.
‘07 Ford 6.0PSD RB-50/E-PH SMB
bigdog is offline   Reply With Quote
Old 06-07-2012, 12:55 PM   #6
geoffff's Avatar
And 4x4 means a solid front axle. This extra unsprung weight would most likely significantly worsen your ride quality.
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 06-07-2012, 02:50 PM   #7
-- Geoff
QuadVan 4x4 vans ride better than stock 2wd vans. I was very surprised when I took one out on a test drive. Some of the RR crossing in NW Portland usually require crawling over at walking speed, even in a car. The QuadVan (RB V10 with 4" lift and dual Bilsteins) took them smoothly.
Old 06-07-2012, 06:25 PM   #8
Two wheel drive is fine, 4 wheel drive just lets you get stuck in worse places...
Tom
2005 SMB RB 50 4X4 w/ a 6.0 PSD
flyfisher is offline   Reply With Quote
Old 06-07-2012, 08:08 PM   #9
BIGVANS's Avatar
If you stay with 2WD make sure you have some sort of a rear locker, or you WILL find yourself getting stuck on wet grass, snow, some gravel inclines, etc.!
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 06-07-2012, 09:06 PM   #10
geoffff's Avatar
Sounds like I need to experience that someday
-- Geoff
