Old 04-13-2014, 11:10 AM   #21
Re: Theres gotta be a trick. . .
After mine came out of the Ford dealership my vans shifters were similar. It has never been the same but did loosen up over time. I do use mine a lot and it seems to be getting better. I think it's a linkage issue. Have you looked under there and seen anything out of the ordinary? For a while I couldn't even get in & out of high 4x4 on the fly.
Old 04-13-2014, 03:13 PM   #22
dmeade0's Avatar
SMB_West has a video on youtube about the Atlas case, here is the url:
05 PSD SMB_4x4 RB-50
dmeade0 is offline   Reply With Quote
Old 04-13-2014, 03:38 PM   #23
Originally Posted by BajaSportsmobile
With our Agile Off-Road system, you just push a button - and you won't trip over the shift levers. Apples and Oranges...
Just rub it in in whydontcha!
edroid is offline   Reply With Quote
Old 04-14-2014, 08:53 AM   #24
I emailed Advance Adapters regarding "break-in" of the Atlas transfer case. This was the reply I received back from customer service:
"Some customers say they break in over time. I personally believe they not only break in a little over time, but I also feel the customer learns to shift the unit by practice. I don't think Hubs have much factor."
So he kinda says the transfer cases might sorta break in, but I must be doing it wrong. . .
Old 04-21-2014, 08:30 PM   #25
REF
REF's Avatar
Send a message via MSN to REF
Just got back from a weekend in Moab, went with some friends that have a somewhat new to them '06 w/ the atlas, we played around with things for a bit and explored top of the world trail. We found that by putting the rear into neutral we were able to shift the front into 4 low followed by shifting the rear into 4 low.
Old 05-11-2014, 09:11 PM   #26
Finally! I thought it was just me....When I bought The Van new in 2005, I could shift into 4X4 on "the fly", as advertised. But after about 5 years and 40k miles, I could only shift into 4X4 while at a complete stop. Now, I have to plan ahead, and be at a dead stop to shift into 4X4, not a big deal, but would like to know why my Atlas TC decided to change the program. All my other four wheel drive vehicles have had the old fashioned 4X4 that required stopping to shift, but don't know why the Atlas has changed.
Tom
2005 SMB RB 50 4X4 w/ a 6.0 PSD
flyfisher is offline   Reply With Quote
Old 05-11-2014, 11:41 PM   #27
I've found it's kind of like shifting a manual transmission without using a clutch. It just involves more like, RPM's, terrain, steering position, and speed becoming some of the factors.
Old 05-10-2019, 12:52 PM   #28
Using the Atlas
Yep, had to go into 4WD yesterday. Lots of playing. Got it to work.
soloalpinist is offline   Reply With Quote
Old 07-14-2019, 10:57 PM   #29
Advanced Adaptors also makes a cable shifter kit for the Atlas transfer case. I had it on my Jeep and it worked well. Buy the gears are straight cut so...it takes some finess to get it shifted into 4x. Inching forward or backward with the front hubs locked is the technique I used most often.
2006 RB E250 Ford High top, Diesel 6.0 Bullet Proofed (ouch $) 4" Camburg Eng. Lift, Method Wheels, 33" Toyo AT, RB50 interior (homebuilt)
upsidedown is offline   Reply With Quote
