Old 03-12-2012, 08:54 PM   #1
Tire Pressure - Off Road, Low or High?
I've read through a lot of the threads, but they got a bit too complex for what I hope is a more basic question. When going off road, as far as preventing over-heating and tire failure, are lower pressures (thinking 30-40 psi) or higher pressures (50-60 psi) better?
Pete is offline   Reply With Quote
Old 03-13-2012, 09:05 AM   #2
If your goal is to protect your tires, high pressure does that. Some of the reasons to lower your tire pressure are to improve traction and smooth out the ride.
Current: 2014 15 Passenger V8
Former: 2009 SMB 4x4 6.0
Old 03-13-2012, 10:25 AM   #3
Jeffrey's Avatar
Re: Tire Pressure - Off Road, Low or High?
Yes, lowering pressure is good for traction and comfort, but it can serve to protect your tires in some situations by flexing against sharp objects rather than puncturing. Even that's a tradeoff since lower pressure can cause pinch flats.
Old 03-13-2012, 01:48 PM   #4
woodbee's Avatar
On the highway I run 70psi on the front and 80psi in the rear. Off roading I run 50psi in the front and 60psi in the rear. When I came through Steel Pass, I think I would have taken chunks out of my aluminum rims if I had been any lower. Check these pictures of when did Steel Pass. http://beckersminerals.com/pages/dvn..._3_2010-2.html
When the washboard bumps are bad I just slow down and I can still run down the highway at a good speed without airing up.
Running lower pressurs would make me worry about the sidewalls
Woody
2009 White E-350 Modified EB-43, 4x4, 6.0 PSD
woodbee is offline   Reply With Quote
Old 03-13-2012, 01:54 PM   #5
Tapatio's Avatar
Good article from ARB on the subject.
http://arbusa.wordpress.com/2011/10/...ire-pressures/
Callsign KK6GIY
Old 03-13-2012, 05:21 PM   #6
Jeffrey's Avatar
Woody
Depending on tire size and air volume, that pressure would vibrate my teeth out. I run your off road psi as my on-road pressure.
Old 03-13-2012, 05:27 PM   #7
http://www.sportsmobileforum.com/pos...ply&f=3&t=8726
Bad link.
Old 03-13-2012, 05:37 PM   #8
viewtopic.php?f=3&t=5245
Try that link.
Old 03-13-2012, 05:54 PM   #9
Tapatio's Avatar
Bad link.
Fixed
Callsign KK6GIY
Old 03-14-2012, 07:52 AM   #10
scatter's Avatar
Lots of other info here on the forum. For what its worth, I run 50 psi on pavement and 2O to 25 psi in the dirt.
Scatter
2007 RB50, 6.0
K1WGB
