Re: Tire Pressure - Off Road, Low or High?
I saw an article recently testing Toyos, BFG AT/KOs and the Hankook RF10. Interestingly, the BFG's sidewall didn't decrease in size at lower pressures as much as the others. Being rather more avid offroaders, this was not seen as a good thing.
Since SMBs are heavy the load range of the tires makes a difference. As does size; in general, bigger is better and you might not have to air down as much as someone in a Jeep. But it's still a good idea; allowing the tires to conform to objects means more traction and less pressure per sq in. Both good. Your sidewalls may be fractionally more vulnerable, but the other factors more than make up for that.
Where I see people with problems is when they air down and then drive like they have street air. That means more tire flex, wearing out the tires, and of course more force on the side if you turn sharp.
And most of us are using tires designed to air down.
Rob
