Old 01-16-2009, 10:45 PM   #11
Originally Posted by adventureduo
I just had that spacer from aluminess also and sold it to someone on the board, because when i went from 33's to 35's my tire fit just fine. I guess i got lucky.
I bought it just to see what it was. Jage, I'll sell it to you for the $10 + shipping I paid for it. If it doesn't work for you, you should be able to make a simple spacer for the adapter to get the width you need.
Let me know.
LOL! We should sign it and just keep passing it on LOL
Dave and Yoshi [Ki6LBB]
https://www.adventureduo.com
Tread Lightly! Trainer
Pack it in Pack it Out>>>> https://www.trasharoo.com
Old 01-16-2009, 11:12 PM   #12
Except what would hold my tire up then?
Old 01-18-2009, 06:09 PM   #13
Originally Posted by Greg In Austin
Has the spare tire carrier changed? or are there more than one version?
Our 35inch Coopers fit fine.
Yes Greg, I seem to remember SMB saying Aluminess made a slight change to the newer bumpers so 315s would fit.
Old 01-30-2009, 10:58 PM   #14
Re: Tires too Big for Aluminess
Still an issue, the Aluminess spacer I obtained was for 8x170mm.
In addition, I don't have any shop tools so pressing out the studs from my existing swing arme does not seem possible (I really don't want to tear up my swing arm either, monkeying around with the vice).
The main thing I learned from Dave @Aluminess is that they are engineered to compress the tire against at least two points on the arm/hinges. If you don't have this- just hang the tire out in space, you'll get broken welds from the bouncing.
So.... still dont' know what I'm going to do about hanging my 305s out there.
Old 02-10-2009, 11:09 AM   #15
When I mounted the Aluminess tire rack, my tires were too large (33"), too much backspacing and a different bolt pattern (8 x 170mm). So, I made some spacers:
[album:21yi6tlg]3939[/album:21yi6tlg]
I used the same wheel lock as on the van, both on one of the spacers and on the spare:
[album:21yi6tlg]3938[/album:21yi6tlg]
It would have been easier if the Aluminess flat adaptor would have worked for me.
I'm not sure why the images don't appear. I took the outer brackets off 'img' so I could post what I entered. The url looks good. Let me know what I did wrong.
Anyway, the pictures are in my album. (Thanks Jage!)
Old 02-10-2009, 04:39 PM   #16
Fixed. It looks like for album images you have to use [thumb]8220[/thumb] if you're linking to the gallery. I'll look into why later, but for now it works that way and not with [img] tags (which still work for offsite stuff)... I think it should work either way, no sense in restricting what is easiest.
