Old 06-07-2009, 03:14 PM   #1
What is the set up for changing a Sportsmobile tire!
Dumb question - how do you change a tire on a SMB (Ford E-350) with the higher suspension. Is there a jack that will jack the tires off the ground considering the height of the suspension?
Grebitus is offline   Reply With Quote
Old 06-07-2009, 06:18 PM   #2
Re: What is the set up for changing a Sportsmobile tire!
A piece of 2x4 or 4x4 under the jack will let the factory jack lift high enough.
Old 06-07-2009, 11:52 PM   #3
SMB did offer a 5 or 6-ton telescoping hydraulic "bottle" type jack. A standard hydraulic bottle jack didn't have a long enough stroke. Here is a link to what I'm referring to; http://www.drillspot.com/products/63289 ... ottle_Jack
At one time Dave at Aluminess was going to make a saddle/cradle for this type jack to prevent it from slipping off the axle, you might want to check with him too.
John K.
John Kalmbach is offline   Reply With Quote
Old 06-08-2009, 06:11 AM   #4
Here's a solution that Bryan found and I bought as well.
viewtopic.php?f=2&t=1401&hilit=jack+herb+stand&sta rt=15
[EDIT: Looks like the original image lost it's link. Here's some current info.]
http://www.alltradetools.com/EN-3813.htm
Old 06-08-2009, 08:13 AM   #5
Hey Bronco_Hauler!
Wow that is a wicked piece of kit! Would have to by four, or at least two I guess to make it worth it... ?
+ 2001 Saab 9-5 Aero Hirsch
+ fixed house (Argh)
Old 06-08-2009, 08:17 AM   #6
Yeah, it's pretty cool. I have to thanks Bryanlaws for pointing it out to me. I really like that it has a good size saddle to support the load, as opposed to the small, flat, round disk that a bottle-jack typically has.
I only have one, and carry it in the SMB for tire changes, though I haven't had to use it yet. Should be capable enough to lift and support one tire off the ground. If you had to do front or rear axle work, then having two sure would be nice.
Old 06-08-2009, 08:21 AM   #7
Yes it would make quick work of lifting the van up and locking the stands in one operation!
I see these as not only higher jack but a quick lift system for servicing... I have à 2.5T lift but that is not heavy duty enough for the van... So I spend ages lifting wheel after wheel and chocking with axle stand as I go...
Old 06-08-2009, 10:34 AM   #8
NRL
NRL's Avatar
Send a message via Yahoo to NRL
I carry one of these as backup to the shorter bottle jack.
It did a quick and good job lifting the front end when we re-did the springs and added the air bags.
We'll be making a base and top brace for it but currently it works with the 2x4.
Make sure you carry it in a sealed bag cuz the bottle jacks tend to leak a bit..
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
NRL is offline   Reply With Quote
Old 06-22-2009, 02:52 PM   #9
Larus's Avatar
http://www.hi-lift.com/index.html
From Iceland 1993 Ford Econoline 7,3 e4od Dana 60 front and rear 4:10 difs and ARB lokkers 38" summer tyres
Larus is offline   Reply With Quote
Old 06-25-2009, 02:12 PM   #10
Just took Bronco Hauler's advice and ordered two of the 3 Ton bottle jacks. I will be practicing with them this weekend to see how they work for changing a tire. Alltradetools shipped them in about 5 days for free. Grand total for two was about $65.
Their only drawback so far seems to be that they weigh 3 tons!
2006 Baja Tan SMB 4X4 EB50 PH 6LPSD
Mohawk Royalex Solo 14 foot canoe (light white-water)
Mad River Kevlar Explorer 17 foot canoe (flat water)
Dagger Royalex Legend 16 foot canoe (white-water)
Maravia New Wave 13.5 foot raft (fishing and white-water)
Ed in Montana is offline   Reply With Quote
Queen bee
Deaner
TBD
thatsandrea
