Old 04-27-2012, 11:08 AM   #1
E-350 Cabin Air Filter
Do these vans have a cabin air filter. I see it mentioned on maintenance check off sheets but some times they are generalized. Thanks.
Pat
PatO is offline   Reply With Quote
Old 04-27-2012, 11:55 AM   #2
BIGVANS's Avatar
Re: E-350 Cabin Air Filter
No. Not from Ford. Not positive about 2010 up - I never checked but never read anything about Ford adding one.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Loud Mobile
pinz712
Agnes
alta825
