Old 11-16-2017, 12:37 PM   #1
BrianBlair's Avatar
Front recovery points/front hitches
I've been hunting around for a way to add recovery point(s) to the front of my E250. I'm trying to avoid the usual front hitch as my bumper is fairly low profile and all the add on hitches I've seen wind up 4-5 inches below my bumper. Call me picky but I just can't stand the look of it.
I stumbled on this hitch meant for an F250:
https://www.ebay.com/itm/Front-Mount...oAAOSw5cNYdHXy
I need to double check my measurements but I am fairly certain that the 2" receptacle would wind up flush with or just inside of the lower opening on my bumper. It would basically be tucked away/invisible until you added a 2" hitch recovery point/shackle.
Can anyone see a reason this won't work(assuming my measurements are good). The frame mounts are identical between the E and F series......right?
BB
BrianBlair is offline   Reply With Quote
Old 11-16-2017, 02:38 PM   #2
illking's Avatar
Send a message via AIM to illking
Im interested as well, and share your feelings 100%. Id love to have a low profile recovery point for the front end
www.thevanpires.com
2001 E250 RB30 Agile 4x4
1976 G30 Pathfinder 4x4 SOLD
illking is offline   Reply With Quote
Old 11-16-2017, 05:31 PM   #3
TomsBeast's Avatar
That's a pretty slick front hitch! And not a bad option if you aren't ready to upgrade to a plate bumper with D ring tabs built in. You might have to do some modification to put it behind your van bumper, but it's hard to tell without looking at a truck and a van, side by side.
Old 11-16-2017, 06:17 PM   #4
BB
Who says?......I'd get confirmation before pulling the trigger....
Old 11-16-2017, 06:47 PM   #5
Bbasso's Avatar
Rather low profile imho...
Rob.
Current:
And had three other E350s...
Old 11-18-2017, 04:02 AM   #6
Pschitt's Avatar
I guess I know this van Bbasso ;-)
Old 11-19-2017, 01:27 PM   #7
Here's what's on mine. S-K did the original front hitch, essentially a full custom job. Then I had some guys put a platform on and mount the winch.
Old 11-19-2017, 01:31 PM   #8
Pschitt's Avatar
Good job, looks fine!
Old 11-19-2017, 03:12 PM   #9
Blowby's Avatar
I was after a front hitch so that I can put a bike rack on it,so I bought a Curtis hitch thinking that I could bolt it right in.Well that wasn't to be as with the SMB mods for 4 wheel they add the leaf spring assembly where the install would have been.
That obviously is my mistake from being a newbie SMB owner,anyhow I decided to install it as a modified bolt in as I am not a big fan of welding modifications if I don't have to.
Blowby is offline   Reply With Quote
Old 12-05-2017, 10:15 AM   #10
BrianBlair's Avatar
Does anyone know for sure if the bolt spacing/pattern is the same between E and F series? I could swear I've read that in multiple places but now I can't find that info. I'd really like to try this hitch but need to confirm that first.....
BB
