So I got my 265/75/16's and could use a lil more clearance.
Truck has got a 2" body lift to accommodate drop floor for wheelchair access.
I got some MOOG CC880 springs, yet to go in and local spring shop is going to level my truck left to right and bring up the saggy rear some.
Before I do those things though I want to source some longer shocks.
Looking for Bilstein but can't find specs for length to try to source something that'll fit up. Not set on them and welcome any suggestions you've got.
To sum up it's a 2011 E-150 2wd, going to 1.5" Front Coil lift and 2.5" rear.
90/10 Road/Dirt.
Good call gramps, if one is within striking distance of San Diego it’d be worth getting John B on the job for some solid input.
But it does sound like GimpyG is on it though...
I wouldn't use anyone other than Agile. If you can tell John what your truck weighs, he can send you what you need. I'm sure he could guesstimate if you don't have access to a scale. He just re-valved my stock Fox shocks and I can't believe how much better it drives.
